Results 1 to 10 of 20
Thread: Advice needed on which TD42 for conversion
Threaded View
  1. #16
    Jun 2015
    Make sure the gu engine is only a td42 T with a non NATS pump and non ecu reliant..
    If it's the ecu controlled pump then it's a whole new level of wiring and ecu change.
    Not sure if boost compensation is mechanical or ecu controlled either so best check that out.
    From memory the 2.8 ran 4.6 diffs so if your throwing the td42 box in you may need to hunt for 4.3 diffs or 4.1 like factory. Unless your going to run 35's full time..
    Also I think the 2.8 pinion flange is a bit smaller than the 4.2..
    Thanks for the reply. I just spoke to the guy who is going to do the conversion and he mentioned not to get the electronic pump if I go the GU route. The guy doing the job thinks the GQ silvertop would be the go at that price.
    Do you have an opinion on what the better way to go would be motor wise?
