Results 1 to 10 of 14
Thread: need to drain my fuel tank
    Mar 2015
    Hello just had a quick look under my GQ no drain plug on the tank was reading a few posts by doing a search and someone was saying there is a inspection panel in the floor.
    so if i lift up the floor mat i can get access just dont want to drop the tank out on my own ...... the only reason is the diesel is old and smells like tolulene so doing the full fuel system before i put the new injectors in
    thanks
    Yep.. lift your carpet / vynal and you'll see a hatch with 4 bolts.
    Undo it and you'll find your sender..
    Disconnect hoses and electrical.
    Undo the 6 bolts and carefully lift out.. then suck the tank dry.
  3. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Makka (8th June 2016)
    Mar 2015
    thanks WESTY champion
    Are you renewing all fuel lines as well the may be gunked up as well
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Mar 2015
    well just cleaned out the fuel in there smelt yukky and tasted yukky ......... very very very very yukky ..........cleaned fuel filter houseing ran leftover fuel out of pump now to get a jerry of fresh diesel on saturday and prime it up with new injectors and give her a kick in the guts
    Mar 2015
    oh man really dont put a dampner on my parade
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by Makka View Post
    did you edit this..........................
    not understanding
  10. #8
    Mar 2015
    replying to three dogs should have quoted his to make it make scence
  11. #9
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    as TD said, if you cannot get replacement Fuel Lines,
    get a big arsed compressor and blow it from the engine end to the fuel tank end (not attached to the tank ofcourse) put a rag over the end, and give it a shot of air........... if there is anything on the rag (grot / slime / black gooey shyte) then dribble some diesel down the line and do it again
    and again
    and again
    and again
    until it is clean / clear of crap
  12. #10
    Mar 2015
    Quote Originally Posted by Bigcol View Post
    and again
    and again
    and again
    think i may have to got get my compressor back then
