OldMav
I am glad you are having fun AB. You have a fun rig to drive which is what all this is about not those bragging KW numbers but drive ability in the extreme area. We expected this tiny hi tech turbo to be a good option for producing torque early. That it does very well. I asked Mat to get you to drop boost a bit I did some calc and wanted your rig to be well into safe mode until you get a better intake manifold. If you follow Mats lead here we can go nuts with boost and fuel adjustments on the Dyno up here when you visit September. With the flywheel a bit lighter we safe guard your crank so that's a must have. Balancing the wheel and clutch pack is more than enough to be well into the safety area. And I said 32psi not 30 psi BTW lol.
