Results 1 to 10 of 15
Thread: Replacement Aeriel for my GU Patrol
    Jun 2015
    Sydney, Australia
    Hey Guys,
    I was up in the Watagans last weekend. Had a good time especially that moment you get to rescue a Landcruiser. Pic and video attached for your viewing pleasure. Please dont comment on where that guy was standing for the winch out. I told him like 5 times to move, he kept coming back to there. :| Not sure what he was thinking.....
    Anyway, what I discovered and what I need help with is that the design for the Patrol's aerial is a bit ridiculous. Yes you can lower it, but it doesn't go down all the way. This meant that in the tight tracks it got bent back and forth like there was no tomorrow even when "lowered". So of course it's now nicely kinked and it's only a matter of time till it comes off. I can see that there are replacement ones out there for around the $50 mark, but just wondering if anyone knew of any better options? Ideally a rubber type one similar to a UHF aerial that would work? Or even one that has a nice spring mount? Otherwise this is just going to happen again....
    Thanks guys
    You can buy a combo UHF/am-fm antenna,
    as you said looks similar to your UHF antenna
    I lower my antenna down when 4x4ing and use tunes from the SD card
    177 Post(s)
    Hey mate I have a GME Am/Fm whip antenna that can cop a a pounding! The factory antenna is obsolete and disconnected. As a bonus I now have much better reception in contrast. Right hand side antenna in the photo. From memory it was $40 from Autobarn.
    https://www.gme.net.au/catalogue/ant...hone/aem3.aspx
    PS. That bloke in the photo is asking for a decapitation.
    I had a look at the link and it says that it is DAB+ compatible. Can that to use with a digital TV tuner @threedogs
  5. #5
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Ive got the same GME am/fm whip. Works a treat.
  6. #6
    May 2016
    Quote Originally Posted by Caledwvech View Post
    Thanks guys
    Turn radio, antenna goes away, otherwise see below.
    These require proper antenna band-pass splitters that result in higher than wanted losses. they rarely have enough isolation resulting in the UHF Tx getting into the FM radio too much along with usually blown out SWR. Bloody over these shits on boats.
    Simply run dedicated antenna in correct position and all is sweet.
    Used to sell and install plenty of these but can come with mixed results, GME still hasn't figured out 50ohm antenna on 50ohm coax into 75ohm radio.... Also, the radio plugs can be very touchy and weak. The GME's are really just old 27MHz whips that become 1/2 wave for FM band.
    A stainless steel 1/4 wave whip works well to.
    DAB+ means Digital Audio Broadcast, nothing to do with DTV.
    If you are running the factory head-unit, keep in mind that many run dual-diversity antennas meaning special plug into the radio. You can confirm by looking at the rear-passenger side glass for the antenna element (looks like a demister coil).
    As for any antenna mountings, there are plenty of traps and I see plenty of "FAIL's" daily. I will do up a guide in coming weeks on do's and don'ts.
    There is no legal cure for STUPID!
  7. The Following 2 Users Say Thank You to LostBenji For This Useful Post:
    Hodge (24th May 2016), Woof (24th May 2016)
    Jaysee may have meant DBtv as I have television in my Patrol.
    Of all the antenna out there and on ebay etc the best was from
    a mob in Seaford Vic, about $100 for a 900mm antenna and it works a treat imo lol
    jay see (24th May 2016)
  10. #8
    Jun 2015
    Sydney, Australia
    Thanks for all the info. The issue I have is that I have a VMS system in my Patrol. I cannot put the antenna all the way down and have that on (tracking where we were going). So I lowered it as far as it would allow, but still not enough apparently.
    LostBenji, from what you are are saying - it's best just to go with the standard one? I have pretty poor reception at the best of times. I could try getting one of those GME ones from Autobarn. Couldn't hurt I am sure.
    Oh and that guy in the photo most definitely wasn't standing there when we tried the snatch. Cause you are right. Both him and the photo taker are asking for death if they stayed there....
  11. #9
    May 2016
    The standard radio is dual diversity and is OK for reception. That being said, they still suck at time.
    The GME AEM2 (the bigger one) and AEM3 (smaller one) do work OK, just make sure they are away from other antennas.
    As for the VMS more info please, never heard of it.
  12. #10
    You could buy a powered 12v antenna like the ones
    used in hotrods and have it high up on the inside of the windshield.
    Similar to a single wire taped up high, still good reception or down low
    personal preference on placement, The antenna on my camper is a single wire
    running the length of the rubber seal for the hard lid
