Results 1 to 10 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
Threaded View
    May 2016
    So I'm pretty sure this question has been asked, and I know it'll probably open a can of worms... But... Should I upgrade to Windows 10?
    This is a work pc that is networked to 5 others. Two of them win 7, and three still on xp. I use it for designing, myob, email and Web browsing.
    Will it cause any problems. Is it even worth it?
    NO, leave it be.
    Old saying for you to heed, If it aint broke, Don't fix it.
    As your machine is a work and involves networking to other machines, leave it alone. Upgrading will mean some issues with getting used to interface that is very different to Win7 and XP. MYOB will need to be the latest version as well, if on 19.7 or older then not suited for Win8 onwards.
    You break it, then I will have to drive up there and give you a hard time and fix it.
    1. Go here: http://ultimateoutsider.com/downloads/
    2. The download GWX Control Panel.
    3. Save it to desktop and RUN
    4. Follow prompts to remove nag-note and block the upgrades.
    5. Also go to Win-Updates and make sure set to Critical only, un-tick Recommended.
  2. The Following User Says Thank You to LostBenji For This Useful Post:
    taslucas (23rd May 2016)
