Page 655 of 1057 FirstFirst ... 653654655656657 ... LastLast
Results 6,541 to 6,550 of 10564
  1. #6541
    Wow.... and it still spooled the 7064 lol
    Yep. And the timing control solenoid was shagged.
  2. #6542
    476 Post(s)
    Yeah all the work is in prep of selling. It needed a fuel pump either way. It was so worn I had to get another case for it. Apart from the pump and injectors i have only spent 700 on parts to this point.
    Well atleast who ever buys it, they're not going to get a lemon or something that needs work. Well done.
  3. #6543
    22 Post(s)
    Haha, so not only would it be good to see it with a 12mm, it would be good to see with a functioning 11mm
    96 GQ coil/Cab
    08 G6eT
  4. #6544
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Washed and polished the GU up nice.... Still can't get rid of the real deep scratches but the rest of the body came up looking nice and shiny!
  5. #6545
    177 Post(s)
    Are you selling mate ?
    Mar 2011
    14 Post(s)
    What did you do to your Patrol today!
    Nah not selling it mate. Was just well over due for a decent clean and polish and I had a few days off this week so thought I'd make the most of it.
  7. #6547
    Oct 2010
    Old Bar, NSW
    Fitted a Hema HN7 a few weeks back where the Polaris reversing camera screen was, supposed to plug the camera cable straight in... no.
    Odd plugs that dont match so got a Navman camera and fitted that yesterday and tested last night.
    It's a great improvement being able to see behind the pod again, so afraid of hitting a child.
    HN7 is Ok in the bush but as the paper maps are 1:25000 and the Hema 1:150000 the difference takes a little guess work to hope were on the correct track.
    The old Garmin Nuvi with ozexplorer was better as it gives track names, but in the outback the Hema should come into its own. I am going to take the Garmin just in case.
    Don't like the idea of adding systems and maps as everything fails when I do something like that.
    Macca
  8. The Following User Says Thank You to macca For This Useful Post:
    Sir Roofy (18th May 2016)
  9. #6548
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Supose to have done it yesterday but think I hurt my self
    a tad doing the tail shaft
    checking clutch for vacuum leak ,checked peddle pressure -ok
    checked vacuum hose for pressure -ok
    check hose from clutch servo unit check valve -ok
    inspect lines from servo back to vac tank -ok
    give hoses on top of tank a twist one solid the other
    moved quite easy so put another hose clamp on and
    now tight
    tried the clutch again seems much better now phew
    hope that saves a dollar
  10. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Winnie (18th May 2016)
  11. #6549
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Replaced lower control arms with HD ones.
    Tomorrow I'll replace the upper bushes, need to take the uppers out then drive to a mates dads workshop to use a press.
    Anyone want some standard lower arms? In Bendigo, bushes actually look quite serviceable.
  12. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    blocko05 (20th May 2016), happygu (20th May 2016)
  13. #6550
    Got the drivers side radius arm bushes changed and the arm back in and all torqued up. Will hopefully get the passenger one done tonight. Then the sway bar will get new bushes and link pins. Wheel bearing will get am inspection and adjustment of necessary. And will hopefully pick up the new pump and injectors tomorrow night. All in time for my parts to arrive on wednesday.
    So got the passenger arm done and back in and also torqued up. All my parts turned up yesterday. So turned up a press tool for the panhard bushes and rear control arm bushes. Picked up the injector pump last night as well. All going well I will get that in tomorrow night. Also tonight I replaced front panhard bushes, replaced front sway bar links and bushes, inspected and adjusted front wheel bearings and swapped the wheels over to the factory alloys with the new 265/75/16 Nitto terra grapplers.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (20th May 2016)
