the evil twin
I never said an Alternator needs temp compensation... I said it doesn't have it.
That means that you can't compare Alt output voltage to Battery Charger Voltages etc and it also means that if the battery is hot a high Alt OP voltage will cook it
The current that flows from an Alt thru a Battery is the Charge acceptance rate (CAR).
The CAR is dependant on the physics of battery technology, cell capacity and State of Charge and has no relation to Alternator AH.
Rule of thumb for a standard Lead Acid vented battery at better than 50% charge is the CAR will be max 30% of the capacity IE 30 Amps
The limiting factor to current flow is the physics behind the battery
For the same battery at 80% the CAR will drop to around 15% of capacity.
If the CAR for a battery at a given point in time is, say, 30 amps it won't matter a rats whether you have a 70 AH, 90 AH or 110 AH alternator.
The battery will take the same amount of time to recharge to the same level.
