Page 17 of 77 FirstFirst ... 1516171819 ... LastLast
Results 161 to 170 of 762
Thread: Jay see 1997 GU build up
  1. #161
    Maybe it's broken. Lol
    Seriously tho, are my gauges out or am I running a bit hot.
    You could install an Ecu-Talk??
  2. #162
    As good as they are I'll rather have something like a Bluetooth scan gauge. Got one for the wife's commo, but just need to find s something that suits a 1997 model.
  3. #163
    All seems to be running good now.
    After changing the radiator I was still getting slightly high temps when in traffic or just idling for long periods of time. The new radiator came with a radiator cap I thought I'll keep this aside as a spare if I ever need one. Put it on last night and Temps a much better nothing over 88 degrees and no more green dips in the floor.
    Still would like to work out if the electric fan comes on at 90 or 100 degrees and why Mines was coming on at 96.....
  4. #164
    At least your fan comes on, good to see another thing ticked off.
    You've had the gauges in a few days now, thumbs up or down?
  5. #165
    Thumbs up mate, should have got them from the start.
  6. #166
    Same here I love them, if only they made a matching
    EGT and boost for us ZD30 owners he he
    At least they cover the main engine requirements
  7. #167
    The mob that I got mine from do a boost, but not sure and the egt..
  8. #168
    If I end up selling my Simex. I will be looking at a set of 305/70/16. I want to get a full set of 5 with new 16x8 rims.
    What offset are people running with tyres these size. I know that up to -22 is common, I would like to keep the deep dish look.
    Thanks in advance...
  9. #169
    minus 11 rings a bell but MR may have the answer.
    I ran 305s with MTZs on them , still inside the guards
  10. #170
    After a few weeks with both gauges hooked up I'm happy to report that my coolant temps are between 78-90 degrees with it sitting at 84 most of the time. This is after a new radiator, cap and coolant with demineralized water.
    Oil pressure is at 22 psi (idle) and 52 psi (2800 rpm), specs are idle, above 7 and 2800 rpm 43-71 psi as per manual. I'm due for a oil + filter change within the next 1,000 km, so will see if any difference and I can see the gauges clearly in any condition now.
