Page 16 of 77 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 762
Thread: Jay see 1997 GU build up
  1. #151
    Might be a bottom tank for an auto cooler
    Also noticed you have room on your pod for extra toggle switches
    or indicator leds, like my cruise control
  2. #152
    Yeah, I'll put something there.
    Radiator went in good. Had a look around for a bleeder on the firewall and the closest I found was this.
    The little dog leg that kicks up???
  3. #153
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    If its on a heater hose it'll be it lets the air out don't forget to put the heater on hot
  4. #154
    Quote Originally Posted by roofy View Post
    Ahhhh.
    Went to pick up my son and noticed Green under my car....
    Coming from bottom hose. Another thing to do tomorrow....
    Yeah, it's the heater hose roofy will crack it tomorrow.
  5. #155
    How good are these. I've one on the top hose without a problem, but the bottom hose now has a light leak. Will a screwdriver clamp be better.
  6. #156
    You are better off removing all the OE hose clamps you can find
    Try and find the wide SS worm drive clamps, constant pressure
    clamps are a bit of overkill for water hoses
    jay see (7th April 2016)
  8. #157
    After Yendor comments on TD motor thread regarding the electric fan it got me a little concerned.
    I always thought that fan went on at 90 degrees and the a/c would cut out at 105 degrees.
    Now the fan is going on at 96 degrees, so are these new gauges that I'm happy with not accurate? How would I check to see what's right....
  9. #158
    My condenser fan never comes on and ive had water temps at 115c. I have two condenser fans and something id like to do is add a manual switch to turn them on if needed.
  11. #159
    Maybe it's broken. Lol
    Seriously tho, are my gauges out or am I running a bit hot.
  12. #160
    I wouldn't be too concerned. You'd have to run a capillary temp gauge in the same spot where the new gauge is to compare.
