made a drop down shelf for the back door.
Put some flares on the car to make sure I don't get done with the new tyres outside of guards. Attachment 65470Attachment 65471
BigRAWesty (13th March 2016)
Packed and unpacked it, then packed and unpacked it again, trying to get everything just right for our next foray into the centre.
Got 4 months to go but have to start somewhere.
Got some fiberglass buff and polish for the RTT, it shine again instead of looking like a dirty blackboard!
Macca
BigRAWesty (13th March 2016), jack (13th March 2016), Sir Roofy (13th March 2016)
Bloodyaussie (16th March 2016)
Finally found a solution, Burson's Lilydale ! Good old yanky import ! Adjustable for first thermo start and secondary 15F higher startup! Neat little kit and only needs 1 x sensor not 2 as previously planned :-)
Decided to get under and remove all the rear control arms and apply some never seize too the bolts. As I get this funky creaking sound from the rear and front on the odd occassion when in 4wd and the underbelly is covered in mud. I found the r/h lower arm bushes are pretty well stuffed. Arms are about 2 years old... So new bushes will be ordered...
Plus I ran the TD with the exhaust off. As I have this rattling noise which I thought was the clutch, but the sound stops when I put my hand on the flex section of the pipe. So I remove this section, nothing broken...Dunno.... Gawd it sounds like a freight train though!
BigRAWesty (18th March 2016)
Well its fixed!...............................
My wing mirror that is. Took a while but was on a back order
IF YA DONT GET STUCK YA AINT TRYIN HARD ENOUGH........OR YA TOOK THE CHICKEN TRACK![]()
BigRAWesty (18th March 2016), jack (18th March 2016), katwoman (18th March 2016), threedogs (19th March 2016)
