Results 1 to 10 of 10
Thread: TD42 to TD42Ti
Threaded View
  1. #5
    22 Post(s)
    Quote Originally Posted by Sharky1 View Post
    Cant upload it man. My ph & my laptop aren't talking to ea other. If u PM me ur mob number I can text it to u & u can post it up in ur comments?
    It's cracked on the crown, The crack is about an 35-40mm long & goes from edge of piston to center & then a very fine hairline crack returns to the edge on about a 90deg angle. Crack is pretty much below inlet valve.
    I should add that there was quite a diff in compression between cyls too. 6 & 5 had about 285psi, 4 had 375, 3 & 2 had 420psi & climbing, 1 had 0psi. I had noticed a drop in compression by the power output & tone of the motor in recent weeks.
    Do the longer squirters really make that much of a difference?
    You'll need the squirters to match the piston. Thats how oil gets up under the crown for cooling and lubricating
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Sharky1 (12th March 2016)
