Page 5 of 25 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 241
Thread: Now The Drivers Door Wont Open!!!
  1. #41
    This is just a thought , but do you have the right Patrol, dont you lol
    EDIT::: CHECK NUMBER PLATE
  2. The Following User Says Thank You to threedogs For This Useful Post:
    growler2058 (4th March 2016)
  3. #42
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by Apollofish View Post
    Maybe bite the bullet, remove the front seat and cut the door trim open. Cheaper than some other suggestions.
    How's that for being constructive and sympathetic?
    Probably won't help if it the same problem I had with the actual locking mechanism being broken as the connecting rods won't unlock it.
    Only suggestion is to see a panel beater as they must have seen it before or Mr Nissan as a safety issue. Good luck and let us know how it eventually works as it will happen to more and more of us over time.
  4. The Following User Says Thank You to Wizard52 For This Useful Post:
  5. #43
    178 Post(s)
    Quote Originally Posted by Wizard52 View Post
    I'll echo that - I'm hoping there might be a trick of the trade which makes the resolution relatively painless, but if not I think we need to hear all the gory details! (& I'm not laughing at TD's last post - honest )
  6. The Following User Says Thank You to Cuppa For This Useful Post:
  7. #44
    Pull the window trims off and see if you can get to the mechanism. With the window down of course
    If you do this you should have some access to the lock. The outer window trim does come off with the door shut.
  8. #45
    Feb 2011
    Shed
    45 Post(s)
    I havent had much luck trying to get the window trim off, feels like ill bugger it when ive tried
  9. #46
    Feb 2011
    Shed
    45 Post(s)
    mmmmmm I dont really wanna go cutting a hole in the bloody door
  10. #47
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Tried swearing at it? Doesn't seem to help much.. But makes me feel better.
    2003 GU SIII Auto Grenade. All the goodies.
  11. The Following User Says Thank You to Softy For This Useful Post:
    BigRAWesty (4th March 2016)
  12. #48
    Yeah they are a bugger to come off. Easier with the window down, the inside of the window trim had steel clips. So its made to not come off with ease.
    Or do they have a screw in one end?.... Hmm I cant remember now.
  13. #49
    178 Post(s)
    If it's as Wizard suggests then neither removing the inner trim or cutting a hole in the door sound like solutions, but I guess removing the trim & hoping to find a busted or misplaced connecting rod can't make things worse............. but I reckon a call to Mr Nissan first might be wise.
  14. #50
    You want me to see exactly how it comes off, from my car...
