Results 1 to 10 of 16
Thread: Awning mounting
    Oct 2011
    melbourne
    Awning mounting
    Hi all
    Mounting an awning today on the roof rack. Due to the angle of the rack side arms, the awning is on a slight angle. When setting up the awning i noticed the side arms seem to point a bit skyward causing them to bend slightly when all connected up. Is this going to be an issue or is this normal?
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I had the same issue so I made a couple of angle brackets to make it verticle. Bolted the brackets to the cross pieces that hold the rack.
    Not sure what you mean <do you have a piture or drawing of whats happening,
    What brand awning is it,,,,,I made my own awning mount, in your case you
    wouldnt want things under tension all the time.
    I made my own mounts as well, do you have a roof rack or roof bars??
    Not good to have anything under tension IMO
  5. #5
    Oct 2011
    melbourne
    Thanks guys. Is a steel rack. Cane with some L brackets to mount to the mesh so may try that and see how we go. Wish i had of tight of that before drilling. Oh well lucky the awning will cover them up.
  6. The Following User Says Thank You to beexy For This Useful Post:
    BigRAWesty (16th February 2016)
    Quote Originally Posted by beexy View Post
    If you get stuck come around and Ill see what we can do
    This is what i did....short bolt in the bottom and a longer one at the top with a nut on either side of the roof rack brace so you can adjust the angle...
    BigRAWesty (19th February 2016)
  10. #8
    Oct 2011
    melbourne
    Thanks three dogs. I am a stubborn male so I'll see how we go haha.
    Mudski, is that the L bracket with a longer bolt on the top to a drilled hole?
  11. #9
    Better put some pics so you can get some ideas, now I made the long
    yellow beam because I only have a 3/4 rack and had too much up front flapping around IMO.
    The yellow bar is bolted to the roof rack mounting plates, it was too low so I made the green bits to
    lift it up, its not going anywhere fast if you ask me.
    OOI did you mount it on the left or right hand side??
  12. #10
    Oct 2011
    melbourne
    Sorry double post. Please delete this one
