Page 43 of 50 FirstFirst ... 4142434445 ... LastLast
Results 421 to 430 of 498
Thread: Outback Ideas Recovery points
  1. #421
    Expert King_ady1's Avatar
    Beveridge, Victoria
    Hi everyone need a hand from all those with the factory bar that bolts up to the OE
    shipping tie down point. Basically need to know where that bolt is in relation to the hole.
    EG is it right in the middle if so great, but need a few answers to get a complete picture.
    Thanks in advance for this. as per post from Hodge 411
    On Mine, the bolt is slightly to the rear. Can't see exactly as there is a big washer in the way, but I can see about 2mm gap at the front of the washer. If that makes sense. If u want I could pull the bolt out and take some pics for you.
  2. The Following User Says Thank You to King_ady1 For This Useful Post:
    threedogs (2nd November 2015)
  3. #422
    Its ok now Im making a plate the same shape but 6mm in from all sides with a 12mm x 16mm slotted hole .
    That should allow it to fit all and cover that hole. oh and 4mm thick should do it I reckon
  4. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    Hodge (2nd November 2015), King_ady1 (2nd November 2015), Woof (2nd November 2015)
  5. #423
    Beveridge, Victoria
    That sounds like a win to me.
  6. #424
    Perth WA
    63 Post(s)
    Bloody hell mate, these things have turned into a pain for you
  7. #425
    With the help of Kallen Ive had a heap of washers cut that you can weld on when you flog out the bush end brackets
    on the chassis. They are 40mm with a 16.1mm hole and 3mm thick so easy to weld.
    Just PM if you require some will sell as a set of 4 for $8
    FYI you'll probably want 8 per set.. one each side of all 4 bolts..
    That's what most kits are anyway..
    Just a quick thank you to all for the support through the year,
    have a great Xmas and New Year and stay safe.
    Look forward to all the stories next year, again thanks
    John [TD]
  9. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Hodge (24th December 2015), katwoman (24th December 2015)
  10. #427
    Hi all need some help from the GQ owners out there.
    Im getting some switch plates made for my GU that
    suits the panel on the centre console with a few knock outs for some
    switches, as we all know they are way too small.
    I have the GU one all drawn up and will house 3 x Carling switches
    and one toggle switch of your choice. The size of the GU one is 230 x 30.
    All I need to know is the size of the GQ one If its the same great if not
    a seperate plate will need t be cut. speaking of cutting it will be cut
    from 2mm black perspex.
  11. #428
    I've got my centre console out of the car at the moment John... let me know exactly what you want measured and I'll have a look at it tonight.
  12. #429
    That space where you normally put the lockers switches
    Just measure from the front please trying to make it as
    easy as possible for others
  13. #430
    Bumped for Winnie or other GQ owners
