Page 42 of 50 FirstFirst ... 4041424344 ... LastLast
Results 411 to 420 of 498
Thread: Outback Ideas Recovery points
  1. #411
    Yeah they wont fit I have a proto type here I was going to send to Once Disturbed to trial fit.
    Yell out when you take them back and Ill meet you there. Bummer thats the same as Tuppa and a few others
    I have one finished just needs tweaking.
  2. #412
    Up date on the 4.2td's with the factory bar, Ive been trial fitting them with Eric[hodge]
    finally got a design that fit , picked them all up this morning only to find the Laser Cutter did not include
    my modifications, No biggie they should be ready monday or tuesday morning.
    Happy to have this recovery point sorted at last
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Woof (20th October 2015)
  4. #413
    Must be to do with the airbag requirements on the wagons. I have an 04 ute so has a the same radiator etc as hodge but I dont have airbags. There is quite a difference between to airbag and non airbag compliant bars
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    threedogs (30th October 2015)
  6. #414
    With the help of Kallen Ive had a heap of washers cut that you can weld on when you flog out the bush end brackets
    on the chassis. They are 40mm with a 16.1mm hole and 3mm thick so easy to weld.
    Just PM if you require some will sell as a set of 4 for $8
    BigRAWesty (2nd November 2015)
  8. #415
    I take it yours doesn't have that lip Hodge highlighted in red
  9. #416
    Mar 2013
    Can you PM me with prices please...
    Pm sent mate and roughly what fits what
  11. #418
    Hi everyone need a hand from all those with the factory bar that bolts up to the OE
    shipping tie down point. Basically need to know where that bolt is in relation to the hole.
    EG is it right in the middle if so great, but need a few answers to get a complete picture.
    Thanks in advance for this. as per post from Hodge 411
  12. #419
    what year,i have a gu 2010 with a Nissan factory bulbar and it fitted up no problems?
  13. #420
    Might have explained it wrong , where is the bolt that back[lower] one in relation to the OE tie down hole
    Is it central. I want to cut a backing plate the same shape as the OE shape.
    I think it will be better than using even a HT washer.
    I think about 6mm either side [smaller] with the slotted hole may work, thoughts
    Late edit;; Ive come up with a design that should suit it better, wooo hoooo
