Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 146
Thread: Soft Shackles Group buy. Expressions of interest
  1. #91
    When I went to a different place to get any gear tested it cost per ton so to speak.
    Which I think is wrong. Stretch wont tell you much as it can stretch slowly or fast with the same result.
    I high BS would be the cheapest , so just request a destruction test imo
    They said it costs per setup or time. So once set up you can destroy 100 and it'll cost bugger all more.
    They can do up to 200T. .
    All they will do is fit a big eg 20 ton shackle each end and pull till it breaks.
    I had to make up jigs to simulate a chassis as near as possible, with holes to
    allow shackles to be fitted
  3. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (1st October 2015)
  4. #93
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Any further developments Kallen?
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  5. #94
    Just awaiting some replies on quotes for testing..
    Oct 2013
    Adelaide
    5 Post(s)
    Coooooolllllllll
    "GO YOU CROWS"
  7. #96
    Oct 2013
    Adelaide
    5 Post(s)
    Bump tity bump.
    "GO YOU CROWS"
  8. #97
    I dunno why you mob don't just bite the bullet and buy 'em.
    I can't see the issue.
    Snatch straps aren't "rated" to an A.S. or anything meaningful so it hardly matters about the soft shackle which will be at least 2 to 4 times stronger anyway.
  9. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (8th December 2015), MudRunnerTD (8th December 2015), taslucas (8th December 2015)
  10. #98
    ^^^^^^^^ what he said ^^^^^^^^
  11. #99
    Here ya go... get onto these... http://www.ebay.com.au/itm/Soft-Shac...cAAOSwYHxWKHAr
    Might take a while to get the lanolin off tho
  12. #100
    Well I'm not going to try compete with that.
    There ya go boys..
