Results 11 to 20 of 43
Thread: Redoing my BBQ area.
    UPDATE.
    This is the area that I'm transforming.
    When out to Masters and bunnings and wasn't overly happy with what I found.
    Decided on a Masport deluxe inbuilt 210, from BBQ's & Outdoors in Thomastown, a with natural gas kit.
    Next was bricks.
    500 of them.
    Fridge Ebay special.
    Still need to work out bench, run gas line and get sink and taps.
    Looking to have it all done for around $2k. Better than buying one of those module sets
  2. The Following 4 Users Say Thank You to jay see For This Useful Post:
    4bye4 (22nd October 2015), Avo (23rd October 2015), BigRAWesty (23rd October 2015), NissanGQ4.2 (22nd November 2015)
  3. #12
    Find a bit of time today and I changed to suit natural gas.
  4. The Following 2 Users Say Thank You to jay see For This Useful Post:
    BigRAWesty (27th October 2015), threedogs (27th October 2015)
  5. #13
    Had to put this aside while other things got sorted out.
    One for the gas fitters this time.
    I've got access to gas from a couple different points. Gas meter, hot water service or ducted heating unit.
    The meter and the hot water are near each other, about 25 meters away and the heating is in the ceiling, about 15 metres away.
    Does it make a difference from where I get it from? Hot water probably the easiest.
    Will try to do a dry run with the bricks during the week, to see how it's all going to go together.
  6. #14
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    the bbq i pulled down would have filled that area. it was 6m3 of rubble when i finished, it was way to big for my back yard. it should look great when you finish.
    if you can run all the water gas in the same place i think it would be easier
  7. The Following User Says Thank You to garett For This Useful Post:
    jay see (23rd November 2015)
  8. #15
    Patrol God Stropp's Avatar
    38 Post(s)
    Yes mate hot water gas line will be ok, shorter run is cheaper 😀
  9. The Following User Says Thank You to Stropp For This Useful Post:
  10. #16
    The central heating unit is the shortest run.
    Will work it out with a Plumber.
    Just wanted to know if any would do.
    Thanks.
  11. The Following User Says Thank You to jay see For This Useful Post:
    Stropp (23rd November 2015)
  12. #17
    Finally had things aline to make a start on bricking. My father in law was a brickie and is more than happy to get out of the house.
    A bit stuck on benches, want to use granite and found enough for what I need for $400. Cutting and polishing is another $1000, that's going to wait until I can get it cut and polished for less.
  13. The Following 2 Users Say Thank You to jay see For This Useful Post:
    NissanGQ4.2 (3rd December 2015), Stropp (2nd December 2015)
  14. #18
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    looks like it is starting to come together mate. looking forward to seeing the finished product.
  15. The Following User Says Thank You to blocko05 For This Useful Post:
    jay see (3rd December 2015)
  16. #19
    Advanced qwertytank's Avatar
    Jan 2015
    Galston, NSW
    Looks Like you'll be set for summer. The question then will be, to sit around the new BBQ or get out in the Trol!!
  17. The Following User Says Thank You to qwertytank For This Useful Post:
  18. #20
    Quote Originally Posted by qwertytank View Post
    That's the plan.
    To answer your question, if its bloody hot neither, I'll be sitting in the pool....
  19. The Following User Says Thank You to jay see For This Useful Post:
    qwertytank (4th December 2015)
