Page 570 of 1057 FirstFirst ... 568569570571572 ... LastLast
Results 5,691 to 5,700 of 10561
  1. #5691
    476 Post(s)
    Quote Originally Posted by Skitzyrex View Post
    These are the DBA brand mate. P/n DBA698S. I picked them up for $270 a pair on eBay.
    Cheers mate. SCA can get them for $90, give or take a few $$$. Something im keen to get done soon.
  2. #5692
    Expert Skitzyrex's Avatar
    Jul 2013
    Not sure who SCA are but if you can get slotted rotors for that, snap them up. Bargain.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  3. #5693
    SuperCrap Auto
  4. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    mudski (22nd November 2015), Skitzyrex (22nd November 2015)
  5. #5694
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Mounted my solar panels...
    Now i just have to hard wire them in. Anyone know of a 'good' cheap reliable mppt solar controller? Or am i better off getting a decent pwm?
  6. The Following User Says Thank You to sooty_10 For This Useful Post:
    mudski (24th November 2015)
  7. #5695
    Expert King_ady1's Avatar
    Beveridge, Victoria
    Nice man. I won't be much help on that side. How much did it set u back? I was thinking of doing similar but under the racks.
  8. The Following User Says Thank You to King_ady1 For This Useful Post:
    foggs (24th November 2015)
  9. #5696
    Bendigo
    7 Post(s)
    Quote Originally Posted by King_ady1 View Post
    The panels are 160w bit deals off ebay. To mount i simple bought 2 x 3m lengths of 30x30 3mm alloy angle from bunnings cut to length and then bolted to rhino bars. The alloy was about $30 per length. So all up it probably cost me $70-80 to mount.
    They sit a few mm below the top of the bar. So i could still put stuff on top if i desired.
  10. The Following User Says Thank You to sooty_10 For This Useful Post:
    lucus30 (24th November 2015)
  11. #5697
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Nice sooty_10. I've thought about doing this for my rack but I'd put it under the mesh on a slide so i could pull it out the back or front when at camp. That way you still get the full use of the rack and still get a small trickle charge even under the mesh when not using it
    Similar to this
    Lucus30's 1999 GU ST TB45E
  12. The Following 2 Users Say Thank You to lucus30 For This Useful Post:
    foggs (24th November 2015), Majestic (24th November 2015)
  13. #5698
    Beveridge, Victoria
    Similar to this
    Haha that's exactly what I was thinking of
  14. The Following User Says Thank You to King_ady1 For This Useful Post:
    Stropp (24th November 2015)
  15. #5699
    Bendigo
    7 Post(s)
    Similar to this
    Yeah i did think of using drawer rollers for it. But as I'm simply storing it there and will pull down when at camp for any length of time i couldn't be bothered trying to work it out 😆 Loosen 2 turn knobs and mine slides right out and can be set-up on the ground. (Padlocked for security too)
  16. #5700
    Expert Ibbo's Avatar
    Mt Barker, SA
    Bought a second hand rhino rack and put on. Not the prettiest bit of kit but should be strong, aerodynamic and functional.
    2010 GU, 2in lift, old man emu suspension, duellers, arb bullbar, dual batteries, safari snorkel, scangauge2, rhino rack platform, saving for more......
