Page 26 of 101 FirstFirst ... 2425262728 ... LastLast
Results 251 to 260 of 1003
Thread: Hodge's new 4.2
  1. #251
    177 Post(s)
    Put a set of new shoes on. Mickey Thompson P3's in 285/75/16 on a set of black rims. Also painted the rusty hubs as it looked bad with new rims on. Just have to fix the front hubs now looks pretty shit.
  2. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    bsteveo (6th January 2016), MudRunnerTD (18th November 2015), Rocket55 (11th November 2015)
  3. #252
    Patrol Guru Rocket55's Avatar
    Sydney
    That looks great mate! Heard lots of good reports on those tyres also. What offset rims did you get?
    Cheers Rod
    My Build 2005 TD42TI
  4. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (11th November 2015)
  5. #253
    Sydney
    Tap and die set ... To buy list !!
    Edit: never used one so don't even know what I'm in for. Live and learn.
    I have a basic set at home 5-12mm or there a bouts. Comes in handy for all sorts of chassis bolts that want to be a PITA. Just run the tap through the hole and it cleans out all the rust, corrosion, dirt and all manner of other crap that makes like difficult, then you can just run the bolt in by hand most times.
    Cheers Rod
  6. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    Hodge (11th November 2015), threedogs (17th November 2015)
  7. #254
    177 Post(s)
    Quote Originally Posted by Rocket55 View Post
    Thanks mate. Great tires, I had the same set, same size on my 3L as well. It is a -22 offset on 16x8" rims.
  8. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (11th November 2015), Rocket55 (11th November 2015), threedogs (17th November 2015)
  9. #255
    177 Post(s)
    I dont like the look of the nut, spring and washer on the originaly tie down point. Need to use a ht washer or possibly a small insert for it.
    Problem fixed. John didn't muck around and made some plates to suit the occasion. Perfect fit !
    Attachment 62740
    Tapatalked from S6
  10. The Following 5 Users Say Thank You to Hodge For This Useful Post:
    katwoman (21st November 2015), Rocket55 (17th November 2015), Stropp (18th November 2015), threedogs (17th November 2015), Woof (17th November 2015)
  11. #256
    Thinking ,,,seeing you've blacked the grill why not that
    chrome on the rear door just saying give it that stealth look
    Still have your flag bracket here too, next time eh.
    I welded mine yours is bolted on via 2 bolts
  12. #257
    177 Post(s)
    Waiting for it to come back from painting. And I'll go from there. Thinking mirros and that rear barn door chrome bit maybe...
    Tapatalked from S6
    Did see one that blacked the area above the doors.
    looked great side on
    Yeah black all the chrome, think about top of rear doors too
  14. #259
    Attachment 62740
    Tapatalked from S6
    That looks tops. Much more professional
  15. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (18th November 2015), threedogs (18th November 2015)
  16. #260
    Yeah was never happy with the big hole on the OE point.
    much better IMO ,
    Thanks to Eric for all the time with fitting etc,
    but the result speaks for itself. very happy
  17. The Following User Says Thank You to threedogs For This Useful Post:
    Woof (18th November 2015)
