Results 11 to 20 of 29
Thread: What is the redline for a TD42?
    Quote Originally Posted by Rocket55 View Post
    Thanks Benny, didn't know that.
    I'm hoping mine will be capable of seeing 4,200 soon.
    You wont need to with the output you will have.
  2. #12
    Mar 2013
    So I shouldn't worry about over reving it?
    What about the smoke?
  3. #13
    Mar 2013
    And is it normal for the boost to start to fall away when reving it out?
  4. #14
    Patrol Guru Rocket55's Avatar
    Sydney
    Rodney you mentioned your s won't go above 3000-3200. How is it different to mine as I can easily drag a gear out to 3500-4000 range on road.
    I find that a tad over 3,000 it just wants to stop. Mind you I do tend to drive it around on 2/3 to 3/4 throttle. Next time I drive it I'll ring it's neck and see what it does.
    Cheers Rod
    My Build 2005 TD42TI
  5. #15
    Sydney
    Will it free rev to 4000rpm?
    Don't know. never tried it.
    Cheers Rod
  6. #16
    Mar 2013
    What about the smoke? its more noticeable at night with headlights behind me looking in the rear vision mirror...
    What about the boost falling away when I rev it out?
    Are these things normal?
  7. #17
    Sydney
    Quote Originally Posted by SKID View Post
    Keen to ssee if mine does this as well. My boost is set it 12psi.
    Cheers Rod
  8. #18
    Sydney
    During the day I can't really see any noticeable smoke (there is some though) at all in the mirror, but at night it does look like a bit of a smoke screen on anything above 1/2 throttle and about 2,000rpm.
    I have read somewhere that the soot particles really reflect the light which is why they always look much worse at night. Don't know how true this is as I read it on the internet... Don't know if soot lights up anymore than just regular fog/smog.
    Cheers Rod
  9. The Following User Says Thank You to Rocket55 For This Useful Post:
    SKID (6th October 2015)
  10. #19
    22 Post(s)
    What turbo, what injector pump?
    96 GQ coil/Cab
    08 G6eT
  11. #20
    Mar 2013
    No idea, I've only owned the truck for about 2 months, the conversions was done by the previous owner...
