Page 12 of 101 FirstFirst ... 1011121314 ... LastLast
Results 111 to 120 of 1003
Thread: Hodge's new 4.2
  1. #111
    177 Post(s)
    LOL funny fuker, is that how you fixed your aircon :P ??
    177 Post(s)
    I reckon Eric there will be just two screws holding the butterfly plate on the shaft. Inside the unit. Undo the screws and remove said plate.
    I'll open it up and have a look when i get the car back. Have to come and buy the plate off you too.
    Patrol Guru Rocket55's Avatar
    Sydney
    It's easy as Eric. Mark is on the money. Remove the pipe work, undo the 4 bolts that hold it on the Intercooler. You'll then see 2 little brass screws that hold the butterfly to the spindle, simply unscrew them. They're a bit tight so be careful not to butcher the screw heads. Reassemble. It would be virtually next to impossible to do it on the car. You'll end up with these bits left over.
    I got it off the forum (or the other one, can't remember) on the benefits of removing it. It certainly fixed my flatspot at about 2,100rpm. Can't comment on what it did to my boost as my boost is wound up a bit (12psi) through a boost controller gadget.
    Cheers Rod
    My Build 2005 TD42TI
  4. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (24th August 2015)
  5. #114
    I removed my entire egr system. Egr pipe, egr cooler, vac lines, solenoids and butterfly.
    The "throttle body" is there so at a determined point programmed into the ecu it will close and allow more exhaust gas to enter the intake manifold. Exhaust Gas Recirculation (EGR). Now the td42 system is very basic and can be removed without anything happening, no engine light, limp mode etc etc. It will not effect boost.
    I would recommed, if you havent already, block the egr and remove the butterfly at the very least. Removing the egr cooler will remove some load from your cooling system if you go this far.
  6. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (24th August 2015), Rocket55 (24th August 2015)
  7. #115
    177 Post(s)
    Thanks for clarifying that up fellas ! It's a no brainer, block the egr remove the butterfly... This weekend !
    Sydney
    If you were to block the EGR on the turbo side would you achieve the came cooling advantages whilst maintaining the "look" of having the system in place should the plod look under the bonnet?
    Cheers Rod
  9. #117
    Quote Originally Posted by Rocket55 View Post
    You may but is essentially another area of heat soak for the coolant. You probably wont see any readable difference on a gauge but anything can help with a patrol cooling system.
    You could just as easliy block the coolant ports.
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (28th August 2015), Rocket55 (24th August 2015)
  11. #118
    177 Post(s)
    Got the car back today. Few things done. New bullbar, compressor, 2" OME lift kit, roof rack, awning and most importantly the exhaust ! 3" ...
    Definitely changed the power behavior of the car. Lots more up and go when she gets going and gave it a very nice tone with that sweet whistle.
    While dropping off Mudski at JPC today I spoke to the bloke and he said, within minutes easily will be tuned for lots more down low power now that she has the exhaust on. And in his own words, get the EGR blanked ASAP, which is what I also got today thanks to Mudski ! Will be fitted tomorrow amongst a few other goodies...
  12. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    Clunk (28th August 2015), mudski (28th August 2015), Rocket55 (28th August 2015), Stropp (28th August 2015)
  13. #119
    Sydney
    What muffler if any are you running with it?
    Cheers Rod
  14. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (29th August 2015)
  15. #120
    177 Post(s)
    Hiflow muffler thats part of the Beaudesert 3" system.
  16. The Following User Says Thank You to Hodge For This Useful Post:
