Results 1 to 10 of 16
Thread: Running from catch can to sump?
Threaded View
  1. #9
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    Recently I noticed a few people running the hose from there catch cans down to the sump below where the oil return is for the turbo..
    Can any explain the difference to doing this as apposed to running it into the air intake before the turbo?
    The catch can should (normally) have 3 entry/exit points.
    Having the catch can in place stops all of that nasty, oily air getting back into your inlet manifold and clogging it all up.
    Some people choose to take the condensed air and feed it back into the sump (the provent needs an additional non-return valve if you do this), other people just put a tap on there and drain it occasionally.
    Jon
  2. The Following 2 Users Say Thank You to TheFlyingBadger For This Useful Post:
    Sir Roofy (5th August 2015), threedogs (5th August 2015)
