Yep as you say Tony have to go the chop mate, Shame i did not get a heads up on that or it would have been done at the fit up.
so here is the plate that is causing the trouble.
And this is what i am going to cut off it
Check out the placement of the brass brake tubes though = Be bloody careful with that angle grinder.
Didn't need that bit of steel anyways.
I had to do the same... What sh!ts me is I wasn't told to cut off a section of the bump stop bottom plate when i bought the bigger bore shocks
