Results 1 to 10 of 12
Thread: Catch cans
    Jun 2015
    Catch cans
    Hi all
    Geoffs the name ,i am a new member.
    Just wondering if its worth fitting a catch can to a 2.8 motot?
    Thank you for your replies.
    Hunter
    I don't own a 2.8, but I had one on my 4.2 and will soon fit too my 3 ltr should have done it from new but been a bit lazy.
    I would fit one
    GU8 Simpson Pack-Auto 2" lift, Dual Batts
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Catch cans
    Can someone explain to a newbie (me) what exactly is a catch can and what does it do and how does it help?
    I also have a 2.8T
    Quote Originally Posted by SiberianPatrol View Post
    I also have a 2.8T
    Theres a hose that runs from the rocker cover and back to the air intake pipe. This allows crank case vapours to be expelled from the motor and they get recirulated back into the air intake and then through the turbo and into the engine. These vapours are oily and will eventually coat the entire intake with oil.
    What a catch can does is filter the vapours and catches the oil only letting clean/er vapours into the air intake.
    So the catch can is basically fitted inline on this hose running from the motor to intake.
  5. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Ibbo (28th July 2015), SiberianPatrol (27th July 2015), TheCaller (5th July 2016)
    Jul 2015
    Siberia
    Thanks, mudski. I did a but of research last night to learn more about them. One question about the catch can - what is the proper diameter of the hoses used for the catch can? One place I read said that if you use a hose that is too small in diameter, it can kill your turbo because the small diameter, in essence, pressurizes that small system. Any truth to that?
    It also prevents the sensors {maf} getting
    dirty creating poor performance
  8. The Following User Says Thank You to threedogs For This Useful Post:
    Jul 2015
    Siberia
    Any brand suggestions for the catch can? We are swarmed with cheap Chinese aftermarket parts over here, so I want to make sure I get a good one.
  10. #8
    Not sure on the 2.8's but on the 3.0ltrs, in the old scale you'd use 1/2inch ID from the motor and 5/8inch ID to the intake. A lot of people just use 1.2inch for both and stretch it over the larger barb.
    And that too....
  12. #9
    PM Mudski for a price on a Provent 200 and for hose to hook it up use XA
    heater hose it is flared at both ends to make the installation a bit neater.
  13. #10
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Frm this...
    To this...
    Sent from my SM-N915G using Tapatalk
