Page 38 of 52 FirstFirst ... 3637383940 ... LastLast
Results 371 to 380 of 517
Thread: Blocking the EGR Valve
  1. #371
    Northside 4x4 in brisbane do a kit.
    I will also add that thos is only for the 4.2 egr system
  2. #372
    Jun 2015
    I would like to remove it for freeing up the engine bay, easier access to oil filters mostly.... Is it such a big job or bad idea?...
  3. #373
    Bad idea IMO. Illegal for a start, and big fines from the EPA if caught.
  4. #374
    May 2015
    Christcurch
    are you sure thats a zd30 engine? im thinking of doing the same to mine but i tought it was on the other side? reason for asking is my acutators for the turbo are on the back
  5. #375
    Quote Originally Posted by milsomr View Post
    He's got a Td42ti mate....
  6. #376
    Jul 2015
    ORANGE NSW
    I have removed the EGR an all the crap that goes with it even removed the stock intercooler the new intercooler comes with the whole kit to remove egr the 4.2 runs cooler on the egt gauge runs smoother and turbo spools up faster best thing you can do to a 4.2 should work on a 3lt best thing i ever done//
  7. #377
    Quote Originally Posted by moonie View Post
    Its a common mod and most will do it.
  8. #378
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Is it recommended to install a pyro and EGT gauge before blocking the EGR to have a baseline to compare to after the mod? Also is it mandatory to have those gauges after blocking it?
    1999 GU Y61 2.8L turbo diesel; manual transmission; 33" Khumo mudders; ... more mods on the way
  9. #379
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Quote Originally Posted by Ronin View Post
    I have a 2012 as well and would like to know if going the way of Dawes and needle valve is useful or not.
    Crds control boost alot bettr than the di's but id be throwing in a inline catch can streight upp... like mark said cnt go wrng wiv dawes n needle valve.. most people go wiv provent 200 catchcan setup.. i personally run a hpd one n it works a treat...
    Sent from my SM-N915G using Tapatalk
  10. #380
    Jul 2014
    Hey would this work for a petrol engine as well.
    Neil.
