Page 500 of 1057 FirstFirst ... 498499500501502 ... LastLast
Results 4,991 to 5,000 of 10565
  1. #4991
    Patrol Guru Rocket55's Avatar
    Sydney
    Did the EGR block and removed the butterfly from this unit in the red circle in the air intake.
    Fixed my engines reluctance to rev past 2,200rpm and it boosts earlier now.
    Cheers Rod
    My Build 2005 TD42TI
  2. The Following User Says Thank You to Rocket55 For This Useful Post:
    threedogs (12th May 2015)
  3. #4992
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Installed an ebay remote central locking system. Why didn't I do this earlier?
  4. The Following User Says Thank You to sooty_10 For This Useful Post:
    lucus30 (11th May 2015)
  5. #4993
    Is there much involved, for an electronic retard.
  6. #4994
    Bendigo
    7 Post(s)
    Not overly, the instructions were in quite bad chinglish so that took a bit of working out. But other then that the hardest part was routing the trigger wires through to the drivers door. My patrol didn't have a grommet to the rubber conduit, it was a big arse plug from body to door. I got the drill onto it though. Less than $50 all up.
  7. The Following User Says Thank You to sooty_10 For This Useful Post:
    jay see (11th May 2015)
  8. #4995
    Expert Dave_H's Avatar
    Nov 2013
    Whyalla S.A
    Finally purchased a roof rack and can say i love the look of it and life is going to be easier when we go away with 4 kids.
    2008 GU6 ST 3.0 CRD Auto, 2" Lift, ARB Bullbar, IPF Spotties, Side Steps, Maxxis 980 A/T, Roof Rack.....................
  9. The Following User Says Thank You to Dave_H For This Useful Post:
  10. #4996
    476 Post(s)
    Got mine all back together finally last night. Started it up, let it warm up, and I can smell coolant but can't see it. Engine light is still on too. Now do I take some water with me and go for a drive or just leave it in the garage and just pretend the motor is fubar and I need to do a TD conversion? Lol.
  11. #4997
    take water with you,
    try and isolate where that coolant smell is coming from first
    might still be an easy fix,
    does the ECU talk work on yours
  12. #4998
    476 Post(s)
    ECU talk works with mine. I might drop over to Georges after I am sure there is no leaks and see what the error is. I also remove the air resonator box while everything was out and plumbed the vac line for the needle valve directly into the intake.
  13. #4999
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Take it for a drive. You need to be ready to come to Toolangi on the 30th
    Lucus30's 1999 GU ST TB45E
  14. #5000
    Beginner Missy's Avatar
    May 2015
    Mandurah WA
    Absolutely nothing. Not touching it coz it might be traded in the next few days. Not spending any time or maoney on it if im getting rid of it.
    I can do anything the blokes can.
    All Hail the PINK BITS
