Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 107
Thread: 3 x thermo fans stripped in one trip - GU custom brass radiator 6.5 chev GU
  1. #81
    Quote Originally Posted by Nightjar View Post
    Any developments with this mystery?
    haven't heard back yet mate.
  2. The Following User Says Thank You to AB For This Useful Post:
    threedogs (3rd May 2015)
  3. #82
    Nov 2014
    Waikiki, WA
    Waiting waiting!
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  4. #83
    Waiting waiting!
    as am I mate....
  5. #84
    as am I mate....
    Are Davis Craig still helping to find the issue?
  6. #85
    I assume they are mate, I'll have to ask mark.
    The new ones are working fine but we out of summer now and can't really test it in the conditions where they failed last time. I.e towing in 30 degrees for hours, etc.
  7. The Following User Says Thank You to AB For This Useful Post:
    threedogs (8th May 2015)
  8. #86
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Over heating issue, nothing to do with the fans itself is my mechanical answer *LMAO*
  9. #87
    overheating of the motors on the fans or the vehicle engine?
    It is not the vehicle engine overheating that's for sure because it was running cool as a cucumber prior to fail.
  10. #88
    Aug 2010
    17 Post(s)
    Vehicle engine / radiator
    If the motors on the fans were working with no issue when he first got them and only burnt out on a hot day I would lean towards them not being the issue to start with.
    And your cool as a cucumber was only on a needle gauge which means nothing....
    But as I said I'm no mechanic......will be interesting to find out there results
  11. #89
    Vehicle engine / radiator If the motors on the fans were working with no issue when he first got them and only burnt out on a hot day I would lean towards them not being the issue to start with. And your cool as a cucumber was only on a needle gauge which means nothing.... But as I said I'm no mechanic......will be interesting to find out there results
    It has nothing to do with the electronic motors on the fans? They are fine mate...
    It's the plastic fan itself which has let go from the motor spigot nut moulded into the fan core.
  12. The Following User Says Thank You to AB For This Useful Post:
    NissanGQ4.2 (29th April 2016)
  13. #90
    Aug 2010
    17 Post(s)
    Any updates on this Andy???
