No mate unsure if there was specific time in which they changed over. I dont really think its model specific either. The larger h260 diff will have the basket type. Its really anyones guess as to whats in it.
Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Cheetah Outreach
Not exactly. The torsional twist comes from the engine rotation. This happens because the crank is not symmetrical and obviosuly has weight being thrown around. A gearbox has nice straight shafts with near as applicable perfectly round gears.
The only thing that changes is the rotational direction of the output shaft and then obviously the diff.
Not all vehicle diffs aren't symmetrical either... the pinion is offset and the gears helical cut.
This makes the transfer of the torque from the pinion to the crown more efficient with the helix (forward) than against it (reverse).
Thats why mechanical diffs in industry or whatever that need to rotate with equal efficiency and speed in either direction are centre driven and the teeth parallel ground
dom14 (25th July 2015), nissannewby (16th April 2015)
Cheetah Outreach
Cheetah Outreach
Just updating. Engine mounts & gearbx mounts are in good nick.
Clutch oil level is good. No oil leaks either.
So, I'm puzzled about the funny smell of clutch grinding.
Cheetah Outreach
