Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 63
Thread: Dawes and Needle valve issues
  1. #51
    Jul 2012
    N/a
    Makes sense will do some adjustments and go for a spin.
  2. #52
    1/2 a turn at a time by the sounds of it you are nearlly there, keep at it
    you'll turn that frown upside down trust me,,,, he he he
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Dinger (28th March 2015)
  4. #53
    Jul 2012
    N/a
    Cheers mate.
    Just did a 25km run 300c at 110km only got 6 psi dont think that should be a problem though. Was a pretty flat road.
    Egt never went above 400 even up steep incline about 12 degree. So fairly confident it is in a good place.
    I cant thank all that gave me advice enough. You guys are great.
  5. The Following User Says Thank You to Dinger For This Useful Post:
    threedogs (28th March 2015)
  6. #54
    Jul 2012
    N/a
    This is the actuator I removed. Looks nothing like to one I put on looks like it is from a 2.8.
  7. #55
    476 Post(s)
    Quote Originally Posted by Dinger View Post
    Cheers mate.
    110kph boost is too low mate. Get it to around 10-12 and your egts will drop more.
    Dinger (29th March 2015)
  9. #56
    Jul 2012
    N/a
    Cheers mate. Made some small adjustments got it to 9 psi at 110km. Max is 17psi it is not bouncing to 17 very stable and only if I give it a boot full. EGTs went down to 225c at 110km.
  10. #57
    Wow mine must be way off, back to fiddling lol
  11. #58
    Jul 2012
    N/a
    What does yours sit at?
  12. #59
    Flat road sitting on 100 ,[mine is an auto]
    temp is about 320c
  13. #60
    Jul 2012
    N/a
    temp is about 320c
    Mine too.
    Did another run today after a minor tweak and it has moved to 290c I pretty happy though.
