Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 63
Thread: Dawes and Needle valve issues
  1. #31
    Jul 2012
    N/a
    Well it is a most there few more tweaks slowly slowly.
    still think there is something else but will get this right first
  2. The Following User Says Thank You to Dinger For This Useful Post:
    threedogs (22nd March 2015)
  3. #32
    Jul 2012
    N/a
    What I would do here is, remove the dawes, check the spring again, and make sure the spring is not binding up inside the dawes. Sounds to me it is and its not letting the tension off the spring. When you put it back together, wind the dawes in slow and you will feel the spring in there slipping on the adjuster cap, if it feels notchy, check that the spring hasn't dug a small groove in the body of the dawes causing it to catch. I get quite a few people come to me with issues like this and its just the spring causing is from the constant adjust and re adjust. You'll get it soon enough mate.
    Guys should I be able to hear the ball bearing rattling around when I shake the dawes valve with the engine at idle? I am a bit confused over the fact that the actuator arm doesn't move when I turn the needle valve either. Could this be a source of issue?
  4. #33
    475 Post(s)
    Quote Originally Posted by Dinger View Post
    No mate. You have the dawes open way too much if the ball is rattling. Screw in the dawes and try the needle valve adjustment then. If no joy, the diagram in the actuator could be stuffed. The other side of the needle valve. Where is it plumbed in to?
  5. #34
    Jul 2012
    N/a
    That sounds like it could be the issue.
    So winding the dawes in will reduce boost?
  6. #35
    475 Post(s)
    Winding in will increase boost. Take the boost hose off the dawes as it sits now. Before you touch it again. And see if you can blow air though it with your mouth.
  7. #36
    Jul 2012
    N/a
    OK if I can I guess that would be a bad thing?
    so blew in valve and can blow through it.
  8. #37
    475 Post(s)
    So wind it in until I can not?
    If you can, the boost won't rise, any boost pressure will just pass through the ball in the dawes. Wind it in atleast half way and then wind the needle valve in also, right in. (To shut the vacuum supply right off) Then start the car up, and unwind(open the vacuum supply) the needle valve until the rod drops. If it doesn't drop, I would think it's either incorrect plumbing or the actuator is stuffed. Think.
  9. #38
    Jul 2012
    N/a
    Cheers mate
    I will go and give it a crack.
    I have double checked the plumbing a few times against the instructions you emailed the other day.
    thanks again for that
  10. The Following 2 Users Say Thank You to Dinger For This Useful Post:
    mudski (24th March 2015), threedogs (27th March 2015)
  11. #39
    Jul 2012
    N/a
    So this is the set up I think it shows all the parts in the set up.
    I can only get 5 psi out of it at the moment.
    I put a new spring in today (thanks for the fast shipping Mudski)
    I will keep fighting the gremlin just posting an update.
  12. #40
    475 Post(s)
    O.k First thing I notice is the dawes is almost upside down, sort of, lol. I may not affect anything but its best to have the dawes sitting vertically. It just eliminates the possibility of the ball not seating itself right. Next is the clear plastic hose and the Y piece you have, those plastic pieces are prone to crack and leak. The plastic hose I take it goes to a boost sensor or something?
    Can you take a pic of the other side of the intake hose? The needle valve is hiding the plumbing behind there.
