Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Can a clutch fan be re'coed.
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    So I took out my fan today as it was not working. (Had the same resistance when hot as when cold). I was about to do what Parksey had done with his when I noticed that the clutch had the 4 bolts holding the fan in.
    So I removed them and the fan.
    And on the other side there was another 4 bolts that held the 2 pieces together. So I removed them as well.
    And this was the result.
    So my questions are:
    Can I get the oil/silicone to refill it.
    Am I right in assuming that if the resistance is the same when hot as it is cold it means it is not working properly.
    If I can get the oil where do I get it and what is it.
    Sent from my iPhone using Forum Runner
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
    Patrol Guru
    NT
    The oil is silicone oil. People use it to lube up the belts on walking machines. Memory says it was $20 for 50ml off ebay. 50ml is a good amount. Pour it over and bolt together again.
  3. The Following User Says Thank You to P4trol For This Useful Post:
    krbrooking (10th March 2015)
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    i've heard it was at least for sale a few years ago, but most of the time they just get replaced. don't have a clue other than try someone like repco or bursons ect
  5. The Following User Says Thank You to garett For This Useful Post:
    As far as I know you can get it at Toyota.
  7. The Following 2 Users Say Thank You to jay see For This Useful Post:
    krbrooking (10th March 2015), Stropp (10th March 2015)
  8. #5
    Will that help it work or make it worse. Lol
  9. The Following User Says Thank You to krbrooking For This Useful Post:
    jay see (10th March 2015)
  10. #6
    Quote Originally Posted by krbrooking View Post
    Yeah, well
    Probably better to buy a aftermarket replacement, Nissan one.
  11. #7
    Patrol God Stropp's Avatar
    36 Post(s)
    Def get it from Tojo, did mine about a year ago.
  12. The Following User Says Thank You to Stropp For This Useful Post:
    krbrooking (11th March 2015)
  13. #8
    image-441461173.jpg Is this the stuff. Because this stuff is clear and the stuff in the unit is brown and quite thick and claggy/tacky.
    Is that from years of use it is mine different stuff???
    Please excuse my ignorance.
    I have also spoken to two ex mechanics that I work with and they both said they have never heard of anyone opening them up and refilling them????
    How much will I need as well, as I don't think 50ml will be enough.
    Thanks in advance.
  14. #9
    Jan 2015
    north
    21 Post(s)
    pretty sure that isn't it, some can be refilled but it just isn't really worth the time and effort to save a little and u need to find out how much is required, personally i'd just buy a replacement hub, then you know its right.
  15. The Following User Says Thank You to garett For This Useful Post:
  16. #10
    What he said.
  17. The Following User Says Thank You to jay see For This Useful Post:
