They used some of the footage, with different narrative, for the debut of the series. This clip shows the rest of the footage.
Apart from a few jumps by the lead characters + cameraman over a live snatched strap, they're quite welcome to drown their sponsored vehicles.
Autocorrect... Makes me sound like I'm from a call centre.
Great work on here guys. very helpful
Hey all, few quick questions after reading.
So, say I'm bogged deep, and pulling up hill, doing a double line pull. Say, just as a number, with the double line pull, weight on the winch is 5t. Does that mean weight on the pulley is 10t, and as such, the weight on the shackle holding the pulley is also 10t? I only ask, because I haven't seen too many 10t shackles around. Would using two shackles help spread the load, or is it just making it a more lethal projectile?
Also, if I need to winch a car behind me up a hill, but there is no room to turn around, any drawbacks to hooking the winch to a pulley on an anchor say, to my front left, and from that pulley back to their car - provided I can get the rope to their car without hitting mine or anything in the process?
1. Don't try and pull a deeply mired vehicle (uphill, downhill or level) unless you have done everything you can to reduce the effect of the Bog and/or stiction IE some shovel work.
2. If you have 5 ton on the winch on a double line pull then you must have a Unimog on the other end
3. You don't need a 10 ton shackle for recovery work. Shackles are rated to Lifting Standards and depending on grade, a 10 ton shackle will be good for 40 to 70 tons, weigh about 10 KG and be the size of a large dinner plate.
You will find that a very difficult evolution in a practical world IE if there isn't room to turn then there usually isn't room or ideally placed anchor points to rig the redirects required
In a theoretical world you can do it as it is no different to a redircet but in practice don't forget you will need to allow for a friction loss (or load depending) of 10% for each snatch block you use
krbrooking (14th March 2015)
Sorry, I didn't quite phrase my question that well. It's less of a 'not being room to turn', and more, say im going up a hill, and turning is impractical because of angles. I could go up, turn around, and come back down, but that would mean having to reverse back up the hill, which would present it's own set of dangers, and may not be practical. But if it effectively works as a redirect then it should be sweet![]()
you halve the effort you are still pulling what was it 5ton
twice as slow
