Page 466 of 1057 FirstFirst ... 464465466467468 ... LastLast
Results 4,651 to 4,660 of 10564
  1. #4651
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Sold it
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  2. #4652
    Nov 2011
    Toowoomba, QLD
    But I have another on the way!
  3. #4653
    Oct 2010
    Old Bar, NSW
    Cuppa, well done.
    There is no better feeling than the one after successful completion of a good job.
    Some data, pre and post dyno tune.
    New tips were fitted to injectors, pump serviced, glow plugs checked, turbo checked, new filters, pre and post tune run on dyno.
    EGT was 630, now 550 max
    Water range 75 - 105 no change
    Boost was 9.6, now 15.1 max. (They say its about 13psi.)
    Those are my gauge readings.
    RWBHP was 97, now 122 max (at 120 kph 4th gear)
    Over 125 RWBHP needs lots more fuel, so they limit tune for economics in my case.
    I seem to be 2 litres per100 klm better, only one tank so far.
    But what a car to drive, goes so much better.
    Local 5th gear test hill, was 100 at bottom 88 at the top. Now 100 at the top.
    Very happy.
    Macca
  4. The Following 2 Users Say Thank You to macca For This Useful Post:
    Bloodyaussie (15th February 2015), Cuppa (14th February 2015)
  5. #4654
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by cuppa View Post
    a good idea, i’ll do that. When you say ‘keep that in mind when going to the dyno’ & given that i’ve never been near a dyno before, are you suggesting that i just tell the tuner “this is what i plan to be doing with the vehicle” or should i be more specific & ask for specifics e.g. Max egt @ x revs?
    What are the differences in egt’s you see at say 90kph between when you are pulling your ct & when you’re not? (i realise mine will be different due to different motor & different ct, but i’m interested in what sort of variations you might see).
    I was surprised that the egt’s didn’t seem especially rev related, but rather were more ‘work’ related. E.g. Went higher when pulling up hill in a high gear, reducing if i changed down.
    Yet on the flat i could be cruising along at 110 with only 350deg showing. I was also surprised at how quickly the egt’s could rise & fall. Need more time to suss out the relationship between boost & egt’s.
    sounds like you have it under control write down your temps what they are now put your ct on and do exactly
    the same run and speeds you did with out temps will rise a tad quicker and might go 5 or 10 degrees higher
    but the longer the hill temps may go higher
    you,l know after awhile what your temps are running at then its time for your dyno and tell (as winnie said)tuner
    what you intend on doing as in towing and econemy good luck with it mate
    it can get frustrating at times sorting it out to suit your needs
  6. The Following User Says Thank You to Sir Roofy For This Useful Post:
  7. #4655
    Feb 2011
    Shed
    45 Post(s)
    Put the superior engineering sway bar disconnects I got FOR FREE!!
  8. #4656
    Feb 2011
    Shed
    45 Post(s)
    Passengers side stupid forumrunner won't let me post 2 pics in one post
  9. #4657
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    ^^^^^^ stolen ^^^^^^
    Hello from Under Down Under!
  10. The Following User Says Thank You to taslucas For This Useful Post:
    mudnut (15th February 2015)
  11. #4658
    .......... TPC's Avatar
    63 Post(s)
    What???????
  12. #4659
    Expert Majestic's Avatar
    Oct 2014
    Central West NSW
    I bought some shoo roo sonic devices (from SCA for $6) and put them on the Patrol today.
    They should allow me to get a bit laxed with my evasive driving now, I've lost track of the number of close calls I've had out here at 4am in the morning. Those buggers come out of nowhere in the dark.
    Owner of 1984 SD33T MK Patrol
    Owner of 1989 TD42 GQ Patrol
    Previous Owner of a 1988 TB42 DA Maverick
  13. #4660
    Feb 2011
    Shed
    45 Post(s)
    I felt like I was pinching them at that price. I also got front n rear shoes and 30mm spring spacers
