Results 1 to 10 of 12
Thread: Fast flashing since I put in new LED tail lights
    Feb 2015
    Hi, can someone help. I have fast flashing indicators since I installed new LED taillights. ??? Need a relay. If so where does it go or do i need to replace something? I'm in a remote part of WA so have to order things in as there is no "local shop" to go to 4 help. Thanks in advance
    Both indicators or just one?
    Put your hazards on and ensure all four lights are working first then let us know.
    Could also be other faults with the trailer plug/ wiring and I'm sure other things as I'm hopeless with electrics but try that first?
    Jan 2014
    Toowoomba
    You will have to place a pair of inline led resistors as there will be a power drop at the LED. It is a simple fix
  4. The Following User Says Thank You to CPOCSM For This Useful Post:
    rusty_nail (9th February 2015)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    The speed of the flashing is set by the resistance of the lamps. With LED lamps you will have to add a resistor to the circuit to reduce the flash times. Don't know where you are in WA but this is the type of thing you need.
    http://www.supercheapauto.com.au/onl...ecommendations
    This add from SCheap but NARVA should be available from most outlets Repco etc or on line.
    Good luck.
    You just replace the Flasher Relay under the dash near the steering column with an LED compatible one.
    Less than $5 on Fleabay or $15 aussie sellers or $25 retail at Supercheap etc.
    I don't see the point in arrrsing around with load resistors.
    http://www.ebay.com.au/itm/3-Pin-12V...item4868039ea8
    http://www.ebay.com.au/itm/LED-Flash...item3f3b3769b8
    The only time you need to add a load resistor is if your Cruise Control uses the same micro switch as your brake lights and stops working.
    Then you need to add a single load resistor in the brake light circuit.
    If your cruise uses a dual brake switch setup or isn't sensitive to floating voltage then no worries
    Perth WA
    63 Post(s)
    Hey mate, head on over to the Introduction Section and introduce yourself, always a nice thing to do before asking for assistance
    Feb 2015
    Sorry to dive straight in asking questions. Thank u everyone for your help. Will let u know how it went ! Fingers crossed.
  9. The Following 2 Users Say Thank You to Allymac For This Useful Post:
    Stropp (8th February 2015), Woof (8th February 2015)
  10. #8
    Patrol God Stropp's Avatar
    38 Post(s)
    Mate as ET says just get the led blinker relay, it's located behind the dash on the lh side of the steering column, I got one thru eBay delivered foe around $5.
  11. #9
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Allymac View Post
    Hi Allymac , after trying all other led flasher relays . I found this relay works well as you can adjust the speed of flasher and it's cheap from Ebay regards Alex
    http://www.ebay.com.au/itm/161260836...967&rmvSB=true
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  12. The Following User Says Thank You to altech For This Useful Post:
    Stropp (9th February 2015)
  13. #10
    38 Post(s)
    Quote Originally Posted by altech View Post
    thanks for the link, got some good bits there so i bought a double usb socket set.
