Results 1 to 10 of 12
Thread: Fast flashing since I put in new LED tail lights
Threaded View
  1. #9
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Allymac View Post
    Hi, can someone help. I have fast flashing indicators since I installed new LED taillights. ??? Need a relay. If so where does it go or do i need to replace something? I'm in a remote part of WA so have to order things in as there is no "local shop" to go to 4 help. Thanks in advance
    Hi Allymac , after trying all other led flasher relays . I found this relay works well as you can adjust the speed of flasher and it's cheap from Ebay regards Alex
    http://www.ebay.com.au/itm/161260836...967&rmvSB=true
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  2. The Following User Says Thank You to altech For This Useful Post:
    Stropp (9th February 2015)
