Page 26 of 463 FirstFirst ... 2425262728 ... LastLast
Results 251 to 260 of 4627
Thread: ThE dRuNkIn RaMbLiN tHrEaD - dEdIcAtEd To ScOtTy
  1. #251
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by Dhuck View Post
    I wanna check why the light is coming on on the dash. I did a manual ecu check and all was fine
    Too easy - hopefully something that will register first pop ... the only error code I have is 55 which is the error code for having no error codes!!! No sh!t!! LOL
  2. #252
    Patrol Freak hekarewe's Avatar
    Feb 2011
    springfield lakes
    Quote Originally Posted by toddrhind View Post
    take the globe out problem solved *L*
    tooo hard duck tape over offending light much quicker LOL
  3. #253
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    That is the code I get.
    Onya Tod
  4. #254
    Oct 2010
    After a couple read this http://www.gtsparkplugs.com/InjectorSizeCalc.html
    then have a few more.
    My old man said: As far as I am concerned the only way to set up an engine is on a dyno. This way you can see actual figures and results
    If I had all the information needed to calculate the injector size I probably wouldn't need the site!! LOL
    Not saying your old man is off the mark, but a lot of mechanics out there (and bloody good ones) who don't use dyno's ... but I'll leave that argument for you and him to have!!! lmfao!
  5. #255
    Oct 2010
    Onya Tod
    No faults then ... just a dodgy bulb!!! LOL
  6. #256
    Nov 2010
    Crap Weather State
    5 Post(s)
    no only comes on when the accelerator is pressed. Hmmmmmmmm
  7. #257
    Oct 2010
    Well, knowing you don't have any windscreen ducting for airflow, they probably ripped something out when putting the roll cage in ... lucky for you I'm a top bloke and have hunted the net for a solution .. you need to do this ...
  8. #258
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    when its pressed hard???? maybe dirty air filter
  9. #259
    Aug 2010
    17 Post(s)
    Dhuck is it the same warning light as before??? http://www.nissanpatrol.com.au/forum...=change+filter
  10. #260
    Oct 2010
    Yep - could be that - when did you last change/clean the air filter?? Would have copped a hammering at LCMP the other week with dust and such.
