I have the same exhaust wrap from Brunswick Diesels, but no thermo cover (blanket) on the turbo. I might look at doing that.
When you say raise the rear of the bonnet, do you mean simply putting a couple of washers or spacers underneath the bonnet hinge bolts to raise it up a fraction to let air out the back edge of the bonnet?
@Kevin07 - are you referring to one of the ARE bonnet scoops or similar? And this lowered your general engine bay temps by 50 degrees? That sounds like a worthwhile modification if that is the case.
