Results 11 to 20 of 21
Thread: Patrol AC
    welcome to the forum,
  2. The Following User Says Thank You to Avo For This Useful Post:
    gene (25th January 2015)
  3. #12
    Beginner onlyme376's Avatar
    Apr 2013
    gracemere
    Hi and welcome
    assuming it doesn't have climate control the air control flaps are controlled by cable check for the retaining clip that holds the outer of the cable in place i had the heater flap cable on mine come out of the clip which meant i always had hot air might be a similar issue
    2006 gu iv 3l auto st-s wagon
  4. The Following User Says Thank You to onlyme376 For This Useful Post:
  5. #13
    Beginner mattpatrol's Avatar
    Jan 2015
    Darwin, nt
    If the compressor is cooling and the blower is working then it could be pests nesting in the assembly. I had that happen to my nissan pulsar. Welcome to the forum by the way.
  6. The Following User Says Thank You to mattpatrol For This Useful Post:
  7. #14
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    G'day Gene welcome to the forum mate.
  8. The Following User Says Thank You to Sherro For This Useful Post:
  9. #15
    Jan 2015
    Bray Park, Queensland, Australia
    Thanks to all of you for the welcome & advice. I can get the air to blow on my feet, & out of the defroster but none will blow out of the front vents. when in defrost it also blows out of the front window defogger. Thanks,
    Gene.
  10. #16
    Jan 2015
    To onlyme376 It does have Climate Control.
    Gene
  11. #17
    Jan 2015
    Hi this is Gene with the AC problem. When I put my ac on front vent it blows out of the foot well. I can put it on defroster and it will blow out of there & the side window defogger. Luckily the back ac works well so if it keep it on recycle it does cool of. it still will not put any air out of the front vents. Thanks Gene
  12. #18
    Jan 2015
    Hi this is Gene. Somehow I got my Air Conditioner to blow out the front vents and it has been working perfectly. Then yesterday my granddaughter pushed the auto button on the climate control and it switched back to what it was doing before: not blowing out of the front vents.Thanks, Gene.
  13. #19
    So when you turn "auto" off does it go back out the front?
  14. #20
    Jan 2015
    When my granddaughter pushed auto it started blowing out of the feet vents and will not go back to blowing out of the front vents. Gene.
