Page 87 of 570 FirstFirst ... 8586878889 ... LastLast
Results 861 to 870 of 5693
  1. #861
    Patrol God Stropp's Avatar
    36 Post(s)
    scored a set of 4.33 diff gears to fit up to the patrol, she should be a little better now with the extra grunt.
  2. The Following 4 Users Say Thank You to Stropp For This Useful Post:
    Clunk (14th January 2015), Rossco (14th January 2015), threedogs (14th January 2015), Winnie (14th January 2015)
  3. #862
    Oct 2010
    Old Bar, NSW
    Bought a couple of volt meters from eBay.
    The batteries are connected as a bank by their own CB. If one of the CB's opens I have no way of knowing.
    Simple solution is individual volt meters, any difference is indicative of a problem
    Except they read different. I am fussy about this sort of thing.
    Seller is just that and no help.
    Macca
  4. #863
    If you can open one up is there a small pot you can adjust to make them the same
  5. #864
    That will be pretty difficult to set up using single contact C/Bs.
    If the batteries are in parallel, whatever fault condition trips one CB will trip both anyway.
    Can you mount the C/B's so you can see the trip indicator?
    You could try connecting only 1 meter with the meter +ve on one battery +ve and the meter -ve on the other battery +ve
    If both CB's are closed the meter should read 0.0x.
    If a C/B opens the voltage will drift from zeroish as the battery terminal voltages change.
    -ve voltage if one CB opens, +ve if it is the other
  6. #865
    Oct 2010
    Old Bar, NSW
    I thought that but can not see one, they are panel mount so the PC components are all exposed.
    Macca
  7. #866
    Oct 2010
    Old Bar, NSW
    These meters need the voltage they are measuring to make them work, they are 7.5 - 20 volt meters so 7.5 is the minimum needed.
    If have have the right end of the pineapple, that means zero to 7.5 volts is no screen???
    In the situation of both CB's tripping the accessories wont be working, so I think that is covered???
    Macca
  8. #867
    176 Post(s)
    Went to the stealership, got some more coolant and another towbar plug-in harness, as my old one isn't in a good way at the moment.
    Oct 2011
    Essendon
    These arrived for me at work last week and I picked them up at today
    Sent from my iPhone using Forum Runner
  10. The Following User Says Thank You to Drewboyaus For This Useful Post:
  11. #869
    Oct 2011
    Essendon
    And these too
  12. The Following 2 Users Say Thank You to Drewboyaus For This Useful Post:
    Clunk (16th January 2015), Rossco (14th January 2015)
  13. #870
    Nice drew!
  14. The Following User Says Thank You to Winnie For This Useful Post:
    Drewboyaus (14th January 2015)
