Results 1 to 10 of 12
Thread: GQ Auto Transmission Leaking
    Advanced WattsyGQ's Avatar
    Jul 2014
    North West Coast of Tassie!
    Hey all, racked up some kilometres on the GQ over the last week and on the way home yesterday the auto started slipping really bad, mainly when it hit overdrive, any way it got home with overdrive disengaged. I checked the trans fluid today and it read fine on the cold level of the dipstick so I took it for a run to see if it was still slipping, it ran as normal and engaged overdrive fine, as I pulled up in the driveway I could smell the fluid and I could see it leaking underneath so I took these photo's and was wondering if anyone had some more information or advice to where it's leaking from or if its a huge job or not, any help appreciated, cheers.
    Sorry about the photo's being upside down
    1990 GQ Patrol High-Roof
    Soon to be tourer!
    I'd double check that is Tranny Fluid cobber.
    From the colour, amount and where that leak is I reckon it is engine oil from the rear main engine seal... I could be wrong tho.
    In regards your Tranny slipping I am not 100% familiar with the Series 1 transmission as it is diffferent to the Series 2.
    Is your vehicle a Safari import or Aussie GQ... the imports are 24 volt including the electrics in the tranny.
    Mine was a '94 series 2 so the switches and modes are different.
    When was the auto last serviced?
    How hot did the vehicle get?
    If you are really lucky it may just need a flush, valve body tested and filter changes etc
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    WattsyGQ (3rd January 2015)
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    The main shaft seal for the torque converter went on mine and it leaked out of there. But as evil said above, rear main seal of the engine will leak through the same place.
    Hello from Under Down Under!
  5. The Following User Says Thank You to taslucas For This Useful Post:
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    If it's trans fluid it will be leaking from the front seal where the converter goes into the pump but check your cooler lines where they go past the bell housing first to make sure they haven't worn through, if their ok then box out sorry might as well overhaul it while it out seeing it slipped in overdrive.
  7. The Following User Says Thank You to Sherro For This Useful Post:
  8. #5
    Jul 2014
    Hey mate, its an aussie GQ 12V, no idea when the auto was last serviced, i've only owned it for the last 2000 k's. The A/T oil temp light came on for ages (was in the line up for falls festival) and tried my best to cool it in the situation.
    Soon to be tourer!
  9. #6
    Jul 2014
    I see, I'm fairly certain that it's tranny fluid cause its a red colour when you can see it properly
    Soon to be tourer!
  10. The Following User Says Thank You to WattsyGQ For This Useful Post:
    taslucas (2nd January 2015)
  11. #7
    Aug 2011
    North West Tas
    56 Post(s)
    What's the transmission fluid level like?
    Hopefully the overheating wasn't caused by low fluid.
    I'd agree with shero though, sounds like the front seal has gone in the box unfortunately.
  12. The Following User Says Thank You to taslucas For This Useful Post:
  13. #8
    Yep, I'm with the others if that is def tranny fluid... just looked awful black in the piccies so thought it may be engine oil.
    Reckon you need a visit to the Transmission Doctor.
    If there is one thing that hates getting overheated moe than an engine it is an auto tranny.
  14. The Following User Says Thank You to the evil twin For This Useful Post:
  15. #9
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    If your A/T temp light came on it means your trans reached 140 C which is really hot for non-synthetic ATF.
    Your high temp could well be the result of the slippage you mention and, if it has happened frequently, will contribute to seal failure.
    Dropping the pan will tell you a few things.. If it's clean and very little material on the magnet then it was serviced not long ago. If it's sludgy and has a fair bit of metal on the magnet don't waste too much money getting it flushed because it needs to come out. There's no miracle cure..
    John
  16. The Following User Says Thank You to jff45 For This Useful Post:
  17. #10
    Jul 2014
    Trans fluid level is fine, I'm guessing it was just that it was stationary for so long in hot weather that caused the overheating of it
    Soon to be tourer!
