Page 73 of 81 FirstFirst ... 7172737475 ... LastLast
Results 721 to 730 of 807
Thread: EFI to Diesel conversion.
  1. #721
    Jan 2013
    The oil pump is just a gear driven pump that drives off the timing gears. What would you like to know?
  2. #722
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by Dales300exc View Post
    I dont think it has anything to do with my problem I just wanted to see what they look like and I did.
    I have dropped the oil and have been trying to flush out the oil galleries but am not 100% sure of what I am doing.
    I've stayed away from it for a few days and will slowly start back at it again soon.
  3. #723
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Can use diesel to flush the engine, but easier to just use one of the over the counter products. Run the engine with the old oil to warm it up, then drain. Chuck some cheap oil in along with the flush additive and idle the engine for 20-30 mins. Don't drive it or put any load on the engine. Drain again and replace the filter and fill with good oil. You will be surprised how dirty the 30min old oil will come out if it's never been flushed before.
    IMO and should be taken with a grain of salt.
  4. #724
    6 Post(s)
    Quote Originally Posted by Parksy View Post
    Been told to be wary of this method??
    I asked before if anyone had experience with this stuff but got no reply.
  5. #725
    Jan 2013
    Nowra NSW
    5 Post(s)
    I've done it every oil change with the patrol, my wife's commodore and my boss 260. What have you been told to be wary of?
  6. #726
    6 Post(s)
    Older engines that maybe at risk of blowing seals once cleaned with these methods.?
  7. #727
    Jan 2013
    Nowra NSW
    5 Post(s)
    I've heard this also, but if the engine is relying on gum and varnish to seal it, it really needs a rebuild. I did this on my 400000km patrol and its fine.
  8. The Following User Says Thank You to Parksy For This Useful Post:
    Bloodyaussie (9th November 2014)
  9. #728
    Jan 2013
    Yeh not a great deal to do with the oil pump. If you have oil one side and not the other the oil pump itself is working just fine.
    Seals wil only show weakness if they are already worn. Its like the age old "synthetic oil made my seals leak". It never does, its just the molecules are smaller and more of and as such get through smaller weaknesses in a seal that mineral oil wouldn't.
    Flushes (I have never used) I imagine would be a cocktail of chemicals that as a result make a much thinner oil making passing old already tired seals easier.
  10. The Following User Says Thank You to Dales300exc For This Useful Post:
  11. #729
    6 Post(s)
    First drive with turbo fitted....
  12. The Following 4 Users Say Thank You to Bloodyaussie For This Useful Post:
    Clunk (21st November 2014), Hodge (20th November 2014), mudnut (21st November 2014), Parksy (20th November 2014)
  13. #730
    476 Post(s)
    So the oil pressure issue has been resolved it take it?
