Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Hodge's Dual Battery System
  1. #31
    176 Post(s)
    This is what I just drew up quickly. Would this work ????
    Attachment 47203
  2. #32
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    It will, however when you turn your work light switch "manual switch" on your reverse lights will come on
  3. The Following User Says Thank You to Flex For This Useful Post:
    Hodge (17th July 2014)
  4. #33
    brisbane
    One rocker switch on/off/on or on/ on would stop that rather than 2 individual switches
  5. The Following User Says Thank You to megatexture For This Useful Post:
  6. #34
    176 Post(s)
    Quote Originally Posted by Flex View Post
    Yeah I just realized I didn't quiet draw that well. So thinking about it, I need a relay, with 2 of those "86" positions, that are not interconnected, so the 2 trigger sources never end up being in parallel.
  7. #35
    176 Post(s)
    Also, that Reverse switch is the switch at gearbox, it's not an additional switch. I didn't label it right. I'd have the relay at the back of the car, and the reverse wire I'd pickup from loom, on the right, just tap into it, so when it becomes "live" it triggers the relay.
    megatexture (17th July 2014)
  9. #36
    476 Post(s)
    Thanks fellas. Have been going through those threads and some other reading ... It's amazing I work with power every day yet car electrical gives me a headache. lol
    I was looking at Darrens drawing, and it is perfect for what I need... however. With that setup, when I manually turn on the light, the reverse lights will turn on too. This is something I want to avoid.
    In a nutshell I need a relay that can be triggered from 2 different sources ( reverse light and manual switch), yet not interconnect those 2, if that makes sense ?
    If you work it out, let me know. But it's no biggie having the reverse lights come on too. Bit of extra light...
  10. #37
    Sep 2011
    I've modified your drawing, basically I've added a diode between the reverse switch and the relay, this will stop the reverse lights coming on with the manual switch:
    You can buy them from Jaycar or eBay them (Cheap cheap):
    http://www.jaycar.com.au/productView.asp?ID=ZR1004
  11. The Following 2 Users Say Thank You to Flex For This Useful Post:
    Hodge (18th July 2014), threedogs (18th July 2014)
  12. #38
    176 Post(s)
    <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=47204"/>
    Thanks bud. Was thinking of a one way valve ( diode), tried to see if there was a workaround first. I'll go with this though. Will report back. Cheers !
    Sent from my SM-G900I using Forum Runner
    176 Post(s)
    OK. Done some wiring tonight. Bought the diodes as flex suggested. But I actually went down the path megatexture suggested. And below is the updated diagram, of how I've done it. The on/off/on switch replaces 2 switches, or a switch and a diode. Flicked up, is normal/usual position while I'm driving for reverse etc.... Flicked down, is when I want the light on without the reverses, camping/work light etc... And the middle turns them both off. I got all the bits, but haven't finished the wiring yet, on paper it should work, but will find out tomorrow when I put it in practice!
    Quote Originally Posted by megatexture View Post
    Attachment 47241
  14. #40
    476 Post(s)
    That won't work mate. Your diagram is wrong.
    Your tail lights are different to the one pictured...
