Results 21 to 30 of 45
Thread: Hodge's Dual Battery System
    178 Post(s)
    Got all the bits and pieces, ready to go. Just wondering one thing. The negative from battery to battery. I can just ground the secondary, but am I right to also run a cable between each battery too ??
    Yes you can just run a neg cable between the two. It should be the same size cable as the positive. In many cases this is more reliable (& can also make any future fault finding simpler) than using chassis earth.
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    Hodge (8th July 2014)
  3. #22
    177 Post(s)
    Thanks Cuppa. I don't see many people doing this most just ground it to chassis so I thought I better ask if there was a "negative" in running a hard negative between batteries as well as grounding it. I'll do both.
    Sent from my SM-G900I using Forum Runner
    178 Post(s)
    No advantage in doing both. If intending to fit solar down the track I feel there is an advantage to essentially keeping the ’house’ electrics separate to the vehicle electrics.
  5. #24
    177 Post(s)
    Took advantage of good weather today, and finished the dual battery system. Was hard finding a spot for the redarc unit so, i made a stand-off bracket, for it, and fitted the fused on top, works a treat and looks neat. Ran 2 twins to the rear, which I'm yet to terminate into a some form of fridge plug? I'm not sure what the ARB fridge plugs into until I buy one. And one of the circuits will be just tapped into a 6 way box and spread from there onward to lights and other gadgetry.
    Attachment 47164Attachment 47165
  6. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Family4x4 (16th July 2014), mudski (16th July 2014)
  7. #25
    177 Post(s)
    So I want to wire up my spare wheel bracket/light for 2 functions. A reverse light and camping/general rear light.
    Whats the best way to go about it? Put a relay in, that's triggered by the reverse hot wire, and also have a switch that triggers also triggers the relay when I want the light on manually. Does this sound feasable?
  8. #26
    Looking neat mate. As for the reverse light, that's how mine is setup. Comes on with reverse, but I can also turn the rear light on via a switch. Which also turns on the reverse lights to but it's no issue to me.
    How it's done was via a relay but I can't remember how. MudRunnerTD showed me how ages ago in a thread here. I'll see if I can find it if you like bud.
    Hodge (17th July 2014)
  10. #27
    brisbane
    A few option in here for your wiring re the reverse light http://www.nissanpatrol.com.au/forum...n-switch/page2
  11. The Following User Says Thank You to megatexture For This Useful Post:
    mudski (17th July 2014)
  12. #28
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    Hodge loved how you cable tied the spare fuse. Great idea!!!
  13. The Following User Says Thank You to Flex For This Useful Post:
  14. #29
    Heres the thread that Daren helped me with. Starts from about post #19...
    http://www.nissanpatrol.com.au/forum...=reverse+light
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #30
    177 Post(s)
    Thanks fellas. Have been going through those threads and some other reading ... It's amazing I work with power every day yet car electrical gives me a headache. lol
    I was looking at Darrens drawing, and it is perfect for what I need... however. With that setup, when I manually turn on the light, the reverse lights will turn on too. This is something I want to avoid.
    In a nutshell I need a relay that can be triggered from 2 different sources ( reverse light and manual switch), yet not interconnect those 2, if that makes sense ?
    Attachment 47200
