Page 394 of 1057 FirstFirst ... 392393394395396 ... LastLast
Results 3,931 to 3,940 of 10566
  1. #3931
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Quote Originally Posted by Ian2011 View Post
    Fitted a reversing camera and mounted the compressor under the wifes seat so she can have good vibrations.
    Ian, any chance you could post a pic of the compressor mounting? I'm debating locations at the moment...
  2. #3932
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    My compressor is a 150 psi no name jobbie bought at the Wodonga show two years ago. The baseplate supplied allow the compressor to be rotated onto its side. I then used a preexisting bracket under the passenger seat and the mounting screw points. it's pretty snug in there but doesn't obstruct the seat operation. not sure if the pic is any good, should have taken it earlier when the seat was out
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  3. #3933
    Sep 2011
    Australia
    Not sure where that pic went, was using mobile. I will try again on computer
  4. The Following User Says Thank You to Ian2011 For This Useful Post:
    FNQGU (14th July 2014)
  5. #3934
    Sep 2011
    Australia
    If you have a smaller compressor, it will fit under there no worries at all
  6. #3935
    Cleaned the absolute bajeezus out of it... Inside is immaculate now!
  7. The Following User Says Thank You to Winnie For This Useful Post:
    threedogs (14th July 2014)
  8. #3936
    Oct 2010
    Old Bar, NSW
    Any chance of doing mine Winnie?
    It would be appreciated.
    Macca
  9. #3937
    It took me from last Wednesday until today to muster up the courage to even start the job, haha.
    So........... no
  10. #3938
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Thanks for that. Yeah, got to decide whether to use the little ARB portable jobbie or leave that alone as it is handy for a number of other things, and buy a dedicated one for this vehicle. If I can hard mount one somewhere then it is one less thing to pack in.
    I had a look at that big BOSS PX-07 compressor but it is too large. The smaller PX-02 would probably fit. I already have a 25 litre tank from a truck that I think will now fit in the space where my battery used to be under the vehicle. It is BIGGG, but free, and it is super solid so if I can get it mounted it should be nice and handy. Might need a body lift to accommodate it though...
  11. #3939
    84 Post(s)
    I had fitted a second fuel filter a long time ago. It is a pain to prime. A mate suggested using a priming pump like an outboard uses.
    It works a treat. So does the filter. In the last photo the top is a section the primary filter element below is the dirtiest section of the OEM filter. These are 20000 klm old. I believe good insurance, it is up to me to check the sight glass for contamination.
    The hand pump bulb is a ripper of and idea. What pressure is it rated at, or is it under suction at that point?
  12. #3940
    177 Post(s)
    Took advantage of good weather today, and finished the dual battery system. Was hard finding a spot for the redarc unit so, i made a stand-off bracket, for it, and fitted the fused on top, works a treat and looks neat. Ran 2 twins to the rear, which I'm yet to terminate etc...
    Attachment 47163Attachment 47162
