Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Wot to do
    Legendary happygu's Avatar
    I have owned 2 Di's and also 2 CRD's, and my vote is with the CRD's ...... even though I have had no trouble with any of them
    Here is my run down for you
    01 lacked a little low down grunt off the mark when taking off with a load .... Fixed with a chip
    03 More grunt off the mark, and went like a rocket with the chip
    Fuel economy was the same with both Di's.
    07 CRD Better grunt off the mark again, but slower than the 03 rocket. Never bothered with a chip, as it seemed adequate.
    11 CRD Same as 07, but a little less grunty off the line.
    Fuel economy same for both CRD's and use 0.1 - 0.2 litres more per hundred than the Di's
  2. The Following User Says Thank You to happygu For This Useful Post:
    Crate (28th June 2014)
  3. #12
    Feb 2014
    Iceland
    I have had 3 GUs, a 2001 manual, 2005 auto and 2009 manual
    The 2001 was a bit "sluggish", especially taking off. We towed an Ultimate Offroad Camper a lot behind it and even the sub 1,000 weight was a bit of a load on it. This got fixed with a DTronic chip
    The 2005 came about as a Novated Lease car through my work. For some reason, I never liked that car. At the time, we had a 23.5 foot caravan and towing it was a non-stop struggle. I think this car was probably the most sluggish of all of them
    When I bought the 2009 a few months ago, I specifically set out to find a stock, low mileage manual car. This one had some 46,000km on it and was completely stock.
    The main difference between it and the 2001 is much better power on takeoff but I often wish I had a bit more grunt at higher RPM. We tow a 1500Kg offroad van with this one and it's often a bit slow
    Another difference is definitely in the consumption. When towing the Ultimate on difficult outback tracks, the 2001 used some 14 - 14.5L/100Km. When I tow the new van (even on highways), I hardly get much better than 18L/100Kms
    Even though I loved my old 2001 and it never let me down in any way, I still feel the 2009 is in many ways a better car. Back with my old one, the grenading was becoming a known issue so I always had it in the back of my mind and therefore bought extended warranty from Nissan that I kept active till I sold the car. I don't have the same concerns over the engine in the new one. There seems to be plenty anecdotal evidence out there that the latest CRD engines have less issues than the old 2001
    When/If budget allows, I might consider a chip for this one to try to address the consumption issue a bit
    2009 ZD30-CRD Patrol ST Wagon. Bullbar, IPF Spotties, Snorkel, BFG285/70R70, 2" OME Lift, Rear Drawers, UHF, Scangauge, VDO Boost and EGT Gauges in an A-Pillar Pod, More bits
  4. The Following User Says Thank You to apalsson For This Useful Post:
  5. #13
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    Great to have the firsthand feedback, thanks for taking the time to write it up guys.
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  6. #14
    @ Crate if $30k is your budget your better off looking for a 2006 4.2td
  7. #15
    Apr 2014
    Bonbeach
    Yeah 3D that would be nice, but $30k will be the limit inc mods and a 06 TD42 would be beyond that currently (unless its a complete steal). But like I said its a year or more away so that could change :-)
  8. #16
    Mar 2014
    Thanks fellas for making my desicion even harder hahaha.
  9. #17
    Yer good luck with that. Add another 10k and you'll get one.
  10. #18
    Quote Originally Posted by apalsson View Post
    +1
    You can't expect a lot out of a 3L diesel... Especially when towing. I've done just about every mod possible to squeeze the living shite out of my Di and its still a slug. Then I chuck my camper on and its a slug on meth. But it is only a small engine. Hopefully one day it will grenade and then I have no excuse to get real motor. Well got one but I just need to build it.
