Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: What is the best gas/lpg Stove?
    Aug 2011
    Oakland OREGON, but in Aus on holiday
    One Coleman dual burner and one three burner. The dual is 30 years old the other 2 y/o, both work very well.
    2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
  2. #22
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Butane for us , canisters are easy to pack and can be purchased everywhere. Work well on cold damp mornings if you rotate 2 canisters or poor some of the warm water on the canister. Used one in minus 13 in the high country with no issues as the air was dry.
  3. #23
    178 Post(s)
    I also have a Lido Junior & rate it highly. Two burners & a griller. It is a low pressure stove requiring a regulator on the gas bottle. Much quieter to use & better than previous high pressure/direct connection stoves we’ve had to cook on. Also a little larger, better space for a couple of pots/pans. Not sure why but it will actually boil water quicker than those stoves used without a regulator. If considering a Lido Junior be ware that there are 2 or 3 different models. I chose to get the one with the flame out safety cut out, even though this wasn’t legally required for my set up. It added about $100 to the cost! I did make a couple of wind shields for it though that we attach with neodymium magnets as the low pressure flame is a bit easier for the wind to blow out.
  4. #24
    .......... TPC's Avatar
    63 Post(s)
    I have Lido Junior in my camper and works great.
    http://caravansplus.com.au/catalog/p...oducts_id=3822
    I am thinking about getting one of these for my camper as my existing cooker has sprung a leak.
    Have you guys permanently mounted yours and do they have proper mounting points?
    Also where is the gas inlet?
  5. #25
    Whyalla SA
    I got a Webber Baby Q via flybys not used at all..
    When I bought my caravan it came with one of these in a slide out set up:
    http://www.marinebarbecues.com.au/sizzler-pro
    Great BBQ.
    I did some searching and contacted the distributes and up graded it to this:
    http://www.marinebarbecues.com.au/sizzler-deluxe
    Ok caravan has a 3 burner stove in it so I am cheating.
    Now I don't need the BabyQ. Still in its box unused.
    Don't need it at home as I have 2 of these (and one other from Barbecues Galore, got a 5 burner + spit and side burner from them at half price as I made too much noise re their shit products very cheap) :
    http://www.beefeaterbbq.com/signatur...93761_1001221/
    OK greedy 3 BBQs at home. 2 on operation all 7 days a week.
    So who wants to get a Webber BabyQ cheap?
    I have no use for mine.
  6. #26
    Whyalla SA
    Re the comment the BabyQ true. Send me a PM if interested.
    Not looking at full price anyway.
    Unused all I have done is open box to check its all there.
    I have 3 BBQs at home, Colman 3 burner stove and a 3 burner stove in van . I don't need this Webber Baby Q.
  7. The Following User Says Thank You to outback For This Useful Post:
    BigRAWesty (14th March 2014)
  8. #27
    178 Post(s)
    Mine is ‘semi permanently’ mounted I suppose. It is mounted inside the pod, but on drawer slides. To get around any issues with clearances from combustible materials & regulations about permanent gas connections I have a gas bayonet fitting outside close to the stove, & pull out the stove on the slides & plug into the gas to use. Takes a few seconds. Removal from the vehicle altogether to use elsewhere is just as quick & I have a longer hose for this purpose.
    The gas connection is at the left hand rear.
    Mounting was easy, just a matter of drilling some holes in the base/bottom of the griller section. If attaching to a solid flat surface small ‘L’ brackets would work just as well.
  9. #28
    63 Post(s)
    Thanks Cuppa, I have decided this the type I will get.
    Where did you get the bayonet gas fittings?
