I am thinking about getting one of these for my camper as my existing cooker has sprung a leak.
Have you guys permanently mounted yours and do they have proper mounting points?
Also where is the gas inlet?
Mine is ‘semi permanently’ mounted I suppose. It is mounted inside the pod, but on drawer slides. To get around any issues with clearances from combustible materials & regulations about permanent gas connections I have a gas bayonet fitting outside close to the stove, & pull out the stove on the slides & plug into the gas to use. Takes a few seconds. Removal from the vehicle altogether to use elsewhere is just as quick & I have a longer hose for this purpose.
The gas connection is at the left hand rear.
Mounting was easy, just a matter of drilling some holes in the base/bottom of the griller section. If attaching to a solid flat surface small ‘L’ brackets would work just as well.
