Page 334 of 1057 FirstFirst ... 332333334335336 ... LastLast
Results 3,331 to 3,340 of 10565
  1. #3331
    my 15mm coil spacers arrived , now to find a hoist
    front only ATM
  2. #3332
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    got an ecutalk :-)
  3. #3333
    Quote Originally Posted by critta11 View Post
    Big chain supermarkets only use the fuel discounts to get you buying at there supermarket, they don't care about the fuel money, the big money is in the groceries!!! you buy there so you get $$ off your fuel. Therefor not going to the small independent servos who rely on fuel as a main income.
    Yea totally agree. But if yout can offer people the same discount in a local shop then majority will assist the small guys..
    Expert Shaun 4x4's Avatar
    Secrets
    Sold it. Well traded it for a new navara.
  5. #3335
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Quote Originally Posted by Shaun 4x4 View Post
    Hope it was an stx 550 that you traded it for
  6. #3336
    Secrets
    Quote Originally Posted by 93patrol View Post
    Yep it sure is.
  7. #3337
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Did a little painting, 2 days of non stop prep to get into primer.
  8. The Following 3 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    BigRAWesty (5th March 2014), rafa (6th March 2014), Stropp (5th March 2014)
  9. #3338
  10. The Following 4 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    BigRAWesty (7th March 2014), rafa (7th March 2014), Stropp (7th March 2014), threedogs (8th March 2014)
  11. #3339
    Patrol God Stropp's Avatar
    37 Post(s)
    had the front drive checked to try and find the banging noise, had the wheels off checked the manual locking hubs all ok took the uni joints out nothing wrong, dropped the diff nothing wrong, the only thing was a worn wheel bearing so its back together and tested, no noise so will have to give her a workout to see that its ok.
  12. The Following User Says Thank You to Stropp For This Useful Post:
  13. #3340
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Fitted external battery 175 amp Anderson plug and modified jumper leads to suit, no more lifting the bonnet to jump start tojos and pajs for me, Geez I'm lazy.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  14. The Following User Says Thank You to Ian2011 For This Useful Post:
