my 15mm coil spacers arrived , now to find a hoist
front only ATM
front only ATM
got an ecutalk :-)
Sold it. Well traded it for a new navara.
Did a little painting, 2 days of non stop prep to get into primer.
BigRAWesty (5th March 2014), rafa (6th March 2014), Stropp (5th March 2014)
BigRAWesty (7th March 2014), rafa (7th March 2014), Stropp (7th March 2014), threedogs (8th March 2014)
had the front drive checked to try and find the banging noise, had the wheels off checked the manual locking hubs all ok took the uni joints out nothing wrong, dropped the diff nothing wrong, the only thing was a worn wheel bearing so its back together and tested, no noise so will have to give her a workout to see that its ok.
Fitted external battery 175 amp Anderson plug and modified jumper leads to suit, no more lifting the bonnet to jump start tojos and pajs for me, Geez I'm lazy.
6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
