OK - When you scan them you can select the resolution you want them scanned at. Because they are a bit map file, the higher the resolution the smaller the dots that make up the bit map. My files are scanned at high res so my dots are so small I can zoom in a long way before I see pixels. I hope that explains it better.
I realise that, it's not the scanning that's the problem with them it's just there are better maps you can use.
